I tried the display example on Arduino Giga with Display Shield. It is failing with the error below . If I comment out the touch controller part, the display code works fine. I have tested the ‘C’ example using Arduino IDE, and the touch controller works there, so there are no hardware issues. Would love to get some pointers to make the touch controller work.
OpenMV v4.5.2; MicroPython v1.20-omv-r22; GIGA-STM32H747
File "<stdin>", line 35, in <module>
File "gt911.py", line 74, in __init__
File "gt911.py", line 100, in _write_reg
OSError: [Errno 19] ENODEV
Hi, everything works fine for me. I have firmware 4.5.2 installed and ran this script:
# LCD, touch panel and camera example.
import sensor
from gt911 import GT911
IMG_OFFSET = 80
touch_detected = False
points_colors = ((255, 0, 0), (0, 255, 0), (0, 0, 255), (0, 255, 255), (255, 255, 0))
sensor.set_framesize(sensor.VGA) # Set frame size to QVGA (320x240)
lcd = display.DSIDisplay(
framesize=display.FWVGA, portrait=True, refresh=60, controller=display.ST7701()
# Note use pin numbers or names not Pin objects because the
# driver needs to change pin directions to reset the controller.
touch = GT911(
I2C(4, freq=400_000),
reset_pin="PI2",
irq_pin="PI1",
touch_points=5,
refresh_rate=240,
reverse_x=True,
# Create a clock object to track the FPS.
# Capture a new frame
# Draw touch points if touch was detected.
if touch_detected:
for i in range(0, n):
img.draw_circle(
points[i][0] - IMG_OFFSET,
points[i][1],
points[i][2] * 3,
points_colors[points[i][3]],
thickness=2,
# Draw the image on the display.
