程序是新建文件自带的,点击左下角开始后画面出现第一帧(有时甚至不会出现)就停止,有时运行几秒后停止,程序运行结果也随之停止。我再次点击左下角希望结束程序却显示忙碌中。我使用的是h7p lu s
xHi, can you update your firmware to the latest? Do Tools→Install Latest Development Firmware. Also, please use the latest version of OpenMV IDE v4.8.7.
Thank you for your reply, but it’s still not working. The current situation is that when I click the bottom left corner, the device disconnects.
Can you post a video showing what is happening? The H7 plus is extremely solid. This type of failure likely has some weird cause.
sorry, i’m a new user,i can’t post video
i will show you my code
import sensor
sensor.set_framesize(sensor.QQVGA) # Set frame size to QVGA (320x240)
sensor.skip_frames(time=2000) # Wait for settings take effect.ssekuaig
白色阈值 = (245, 82)
上一帧坐标 = None
上一帧时间 = None
x方向速度 = 0
y方向速度 = 0
def 主循环():
global 上一帧坐标, 上一帧时间, x方向速度, y方向速度
当前时间 = time.ticks_ms()
白色色块们 = img.find_blobs([白色阈值], merge=False)
x_str, y_str = "0", "0"
vx_str, vy_str = "0.00", "0.00"
if 白色色块们:
小球 = max(白色色块们, key=lambda b: b.area())
当前坐标 = (小球.cx(), 小球.cy())
if 上一帧坐标 is not None and 上一帧时间 is not None:
时间差 = time.ticks_diff(当前时间, 上一帧时间)
if 时间差 > 0:
位移x = 当前坐标[0] - 上一帧坐标[0]
位移y = 当前坐标[1] - 上一帧坐标[1]
x方向速度 = 位移x*100/时间差
y方向速度 = 位移y*100/时间差
上一帧坐标 = 当前坐标
上一帧时间 = 当前时间
y方向速度 = 0.0
x方向速度 = 0.0
上一帧坐标 = 当前坐标
上一帧时间 = 当前时间
if 上一帧坐标 is not None:
x_str = str(int(上一帧坐标[0]))
y_str = str(int(上一帧坐标[1]))
x_str = "None"
y_str = "None"
vx_str = "{:.2f}".format(x方向速度)
vy_str = "{:.2f}".format(y方向速度)
print(x_str, y_str, vx_str, vy_str)
img.draw_cross(int(上一帧坐标[0]), int(上一帧坐标[1]), color=(255, 0, 0))
img.draw_rectangle(小球.rect(), color=(0, 255, 0))
if name == “main”:
主循环()
except KeyboardInterrupt:
print(“程序终止”)
I’m not sure if you can use Chinese names for functions and variables reliably. can you post the code with everything using ascii only? I will have an easier time debugging.
I’m borrowing the original poster’s thread to raise some of my questions. I also encountered lag issues. The lag occurs after I extract the facial feature points during face recognition. The whole screen freezes, and then the program stops running. I thought it was a firmware issue, but after updating the firmware, new problems appeared. …
Hi, we are resolving some issues with the newest protocol. Please use the latest stable firmware until we have these resolved.
