Tof vl53l0x arduino Nicla vision freeze
Hi everyone,
I have some troubles with the Tof VL53l0 and perhaps the micopython lib.
After few minutes at low refresh frequency (1Hz) the value freeze.
Do you have a solution for this ?
Hi, I can confirm the default example code for the sensor works on the Arduino Nicla.
# VL53L1X ToF sensor basic distance measurement example.
from vl53l1x import VL53L1X
tof = VL53L1X(I2C(2))
    print(f"Distance: {tof.read()}mm")
    time.sleep_ms(50)
How is your setup different?
Hi, I’m using exactly the same code of you.
Is there a special way to modify the vl53l1x configuration ?
No, if you are using the latest firmware it should just work. Did you remove the tape on top of the sensor? This would cause false readings. However, I didn’t notice any crashing issues.
yes, I evidently remove the tape.
I see the vl53l1x class in openmv librairies with DEFAULT_CONFIGURATION. Can I modify it to change the clock frequency ?
