I am trying to use openmv with the latest firmware to drive a TFTlcd screen with a resolution of 240*320. I try to modify and use the LCD example, but the screen is still white and will indirectly display a blurry screen.
I read the documentation but I don’t know if SPIdisplay supports other screen drivers (my screen driver is st7389v), or if there is something wrong with my code.
from display import SPIDisplay
from pyb import Pin, SPI, millis,hard_reset
import struct
from sensor import alloc_extra_fb,snapshot,RGB565
from time import sleep
x=0
y=0
z=0
press=False
x_original=0
y_original=0
z_original=0
press_threshold=2800
#x_min,x_max,x_step
calibration_data=[29532,796,-89.8,\
#y_min,y_max,y_step
1976,30872,120.4,\
#6:z_min,7:z_max,8:z_x_step,9:z_y_step
27492.0, 17716, -35.0, 10.8667]
calibration_coordinate=((80,60),(240,60),(80,180),(240,180))
baudrate=80
spi2=SPI(2,SPI.MASTER,baudrate=40*1000000,phase=1)
CS = Pin('P3', Pin.OUT_PP)
RS = Pin('P8', Pin.OUT_PP)
def write_c(c):
CS.low()
RS.low()
spi2.send(c)
CS.high()
def write_d(c):
CS.low()
RS.high()
spi2.send(c)
CS.high()
def write_command(c, *data):
write_c(c)
if data:
for d in data:
write_d(d)
def set_resolution(x,y,w,h):
write_c(0x2a)
write_d(int(x/256))
write_d(x%256)
write_d(int((x+w-1)/256))
write_d((x+w-1)%256)
write_c(0x2b)
write_d(int(y/256))
write_d(y%256)
write_d(int((y+h-1)/256))
write_d((y+h-1)%256)
write_c(0x2C)
#baudrate 设置屏幕通讯频率,频率越高刷新效果越好,但高频可能导致显示异常
def init(screen_baudrate=80,pressure=1800):
global calibration_data,baudrate,press_threshold,lcd
press_threshold=5000-pressure
lcd =SPIDisplay(width=320, height=240, refresh=30, bgr=True, byte_swap=True, triple_buffer=False, backlight=False)
write_d(0xa0)
set_resolution(0,0,320,240)#设置屏幕分辨率
baudrate=screen_baudrate
import calibration
calibration_data=calibration.data
except:
#pass
touch_calibration()
def touch_calibration():
global calibration_data,x_original,y_original,z_original
x_record=[]
y_record=[]
z_record=[]
img=alloc_extra_fb(320,240,RGB565)
img.draw_string(115,110,'screen calibration',mono_space=False)
display(img)
lcd.write(img)
timer=millis()
for n in range(0,4):
display(img)
img.clear()
#有触摸
if x_original<32700 and y_original>100:
img.draw_circle(calibration_coordinate[n][0],calibration_coordinate[n][1],4,fill=True)
img.draw_circle(calibration_coordinate[n][0],calibration_coordinate[n][1],13,color=(255,255,0))
img.draw_string(calibration_coordinate[n][0]-4,calibration_coordinate[n][1]-25,str(3-round((millis()-timer)/1000)))
if millis()-timer>3000:
x_record.append(x_original)
y_record.append(y_original)
z_record.append(z_original)
img.draw_circle(calibration_coordinate[n][0],calibration_coordinate[n][1],13,color=(0,255,0))
lcd.display(img,x_size=320)
while x_original<32700 or y_original>100:
display(img)
sleep(0.5)
break
timer=millis()
img.draw_circle(calibration_coordinate[n][0],calibration_coordinate[n][1],13,color=(255,0,0))
display(img)
print(x_record)
print(y_record)
print(z_record)
x_step=(((x_record[1]-x_record[0])/(calibration_coordinate[1][0]-calibration_coordinate[0][0]))+\
((x_record[3]-x_record[2])/(calibration_coordinate[3][0]-calibration_coordinate[2][0])))/2
x_min=((x_record[0]-calibration_coordinate[0][0]*x_step)+\
(x_record[1]-calibration_coordinate[1][0]*x_step)+\
(x_record[2]-calibration_coordinate[2][0]*x_step)+\
(x_record[3]-calibration_coordinate[3][0]*x_step))/4
x_max=((x_record[0]+(320-calibration_coordinate[0][0])*x_step)+\
(x_record[1]+(320-calibration_coordinate[1][0])*x_step)+\
(x_record[2]+(320-calibration_coordinate[2][0])*x_step)+\
(x_record[3]+(320-calibration_coordinate[3][0])*x_step))/4
y_step=(((y_record[2]-y_record[0])/(calibration_coordinate[2][1]-calibration_coordinate[0][1]))+\
((y_record[3]-y_record[1])/(calibration_coordinate[3][1]-calibration_coordinate[1][1])))/2
y_min=((y_record[0]-calibration_coordinate[0][1]*y_step)+\
(y_record[1]-calibration_coordinate[1][1]*y_step)+\
(y_record[2]-calibration_coordinate[2][1]*y_step)+\
(y_record[3]-calibration_coordinate[3][1]*y_step))/4
y_max=((y_record[0]+(240-calibration_coordinate[0][1])*y_step)+\
(y_record[1]+(240-calibration_coordinate[1][1])*y_step)+\
(y_record[2]+(240-calibration_coordinate[2][1])*y_step)+\
(y_record[3]+(240-calibration_coordinate[3][1])*y_step))/4
z_x_step=(((z_record[1]-z_record[0])/(calibration_coordinate[1][0]-calibration_coordinate[0][0]))+\
((z_record[3]-z_record[2])/(calibration_coordinate[3][0]-calibration_coordinate[2][0])))/2
z_y_step=(((z_record[2]-z_record[0])/(calibration_coordinate[2][1]-calibration_coordinate[0][1]))+\
((z_record[3]-z_record[1])/(calibration_coordinate[3][1]-calibration_coordinate[1][1])))/2
z_min=((z_record[0]-calibration_coordinate[0][0]*z_x_step-calibration_coordinate[0][1]*z_y_step)+\
(z_record[1]-calibration_coordinate[1][0]*z_x_step-calibration_coordinate[1][1]*z_y_step)+\
(z_record[2]-calibration_coordinate[2][0]*z_x_step-calibration_coordinate[2][1]*z_y_step)+\
(z_record[3]-calibration_coordinate[3][0]*z_x_step-calibration_coordinate[3][1]*z_y_step))/4
z_max=((z_record[0]+(320-calibration_coordinate[0][0])*z_x_step+(240-calibration_coordinate[0][1])*z_y_step)+\
(z_record[1]+(320-calibration_coordinate[1][0])*z_x_step+(240-calibration_coordinate[1][1])*z_y_step)+\
(z_record[2]+(320-calibration_coordinate[2][0])*z_x_step+(240-calibration_coordinate[2][1]*z_y_step))+\
(z_record[3]+(320-calibration_coordinate[3][0])*z_x_step+(240-calibration_coordinate[3][1]*z_y_step)))/4
calibration_data=[x_min,x_max,x_step,y_min,y_max,y_step,z_min,z_max,z_x_step,z_y_step]
f = open('calibration.py',mode='a+')
f.write('data='+str(calibration_data))
sleep(0.5)
f.close()
hard_reset()
print(calibration_data)
def display(img):
global x,y,z,calibration_data,baudrate,press,\
x_original,y_original,z_original,press_threshold
CS.low()
spi = SPI(2, SPI.MASTER,baudrate=2*1000000,phase=1)
spi.send(0x90)
recv1=spi.recv(1)
recv2=spi.recv(1)
x_original=struct.unpack('B',recv1)[0]*256+struct.unpack('B',recv2)[0]
x=round(( ((x_original-calibration_data[0])/calibration_data[2]) + \
(320-((calibration_data[1]-x_original)/calibration_data[2])) )/2)
if x<0 or x>320:
x=-1
spi.send(0xd0)
recv1=spi.recv(1)
recv2=spi.recv(1)
y_original=struct.unpack('B',recv1)[0]*256+struct.unpack('B',recv2)[0]
y=round(( ((y_original-calibration_data[3])/calibration_data[5]) + \
(240-((calibration_data[4]-y_original)/calibration_data[5])) )/2)
if y<0 or y>320:
y=-1
if x>-1 and y>-1:
spi.send(0xc0)
recv1=spi.recv(1)
recv2=spi.recv(1)
z_original=struct.unpack('B',recv1)[0]*256+struct.unpack('B',recv2)[0]
z=calibration_data[6]+press_threshold-round( (z_original - x**1.02*calibration_data[8] - y*1.02*calibration_data[9]))
if z<0:
x=-1
y=-1
press=False
press=True
press=False
spi = SPI(2, SPI.MASTER,baudrate=baudrate*1000000,phase=1)
lcd.write(img)
