Single Color Grayscale Blob Tracking Example-while blob in black blob--missing
# Single Color Grayscale Blob Tracking Example
# This example shows off single color grayscale tracking using the OpenMV Cam.
# Color Tracking Thresholds (Grayscale Min, Grayscale Max)
# The below grayscale threshold is set to only find extremely bright white areas.
sensor.set_framesize(sensor.FHD)
thresholds = (170, 255)
    for blob in img.find_blobs([thresholds], pixels_threshold=100, area_threshold=100, merge=True):
        if blob.elongation() > 0.5:
            img.draw_edges(blob.min_corners(), color=0)
            img.draw_line(blob.major_axis_line(), color=0)
            img.draw_line(blob.minor_axis_line(), color=0)
        img.draw_rectangle(blob.rect(), color=250,thickness=5)
        img.draw_cross(blob.cx(), blob.cy(), color=250,thickness=5)
        img.draw_keypoints([(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=40, color=127)
the white blob in black blob is missing ,how to find it?
threshold_index = 3 # 0 for red, 1 for green, 2 for blue, 3 for white【<-----------】
              (0, 30, 0, 64, -128, 0),# generic_blue_thresholds
              (29, 99, -47, 115, -47, 127)] # generic_white_thresholds【<-----------】
            img.draw_line(blob.major_axis_line(), color=(0,255,0))
            img.draw_line(blob.minor_axis_line(), color=(0,0,255))
        img.draw_rectangle(blob.rect(),color=(0,255,0),thickness=5)
i run the code of Single Color RGB565 Blob Tracking Example,and the white in the centre is missing too.
Turn off the merge=True argument which merges blobs.
thank you! you are right
