# Single Color Grayscale Blob Tracking Example
# This example shows off single color grayscale tracking using the OpenMV Cam.
# Color Tracking Thresholds (Grayscale Min, Grayscale Max)
# The below grayscale threshold is set to only find extremely bright white areas.
thresholds = (0, 104)#(0, 38, 10, 70, -111, 127)
sensor.set_framesize(sensor.XGA)
from pyb import UART
from modbus import ModbusRTU
uart = UART(3,9600, parity=None, stop=2, timeout=2, timeout_char=4)
modbus = ModbusRTU(uart,2, register_num=9999)
if modbus.any():
modbus.handle(debug=True)
modbus.REGISTER[0] = 1000
modbus.REGISTER[1] += 1
modbus.REGISTER[3] += 3
#print(modbus.REGISTER[10:15])
# image processing in there
for blob in img.find_blobs([thresholds], pixels_threshold=100, area_threshold=5000, merge=True):
if blob.elongation() > 0.5:
img.draw_edges(blob.min_corners(), color=0)
img.draw_line(blob.major_axis_line(), color=0)
img.draw_line(blob.minor_axis_line(), color=0)
img.draw_rectangle(blob.rect(), color=127)
img.draw_cross(blob.cx(), blob.cy(), color=127)
img.draw_keypoints([(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=40, color=127)
win7+ide3.0.3+openmv4 h7 plus.
how to fix that ?
