I just got the global shutter module and installed it on the OpenMV H7. If I try to run a script on the cam I get an error message saying that the “Sensor control” failed. I did not found a setting in the IDE to change the Sensor.
Hi
Can you post the code that fails, and in which line you get the exception?
The global shutter sensor is gray-scale only, perhaps you are trying to run it in colour (RGB)?
Kind regards
Felix
Oh yes thank you! I forgot to turn on Greyscale…
The IDE will auto fix that for you if the camera is connected when you open the script.
