Servo question for h7 plus
I see that the h7 plus has two available I/o pins for two servos. Does this mean that those two I/o pins will safely source their needed power requirements from the attached lipo battery without scorching the h7 circuit?
Also, if I want to power other servos on the other available pins they just need their own battery and everything needs a common ground right? Wondering because not using a servo shield will shrink my project that much more.
Matthew
The I/O pins provide PWM. Not power. So, you can use them for the signal connection the servos need.
So I can power more than two servos on the h7 plus with their own power source correct?
Matthew
Yes, this is correct.
