Camera Module: RT1062
Env: OpenMV v4.5.9; MicroPython v1.23.0-r19; OpenMV IMXRT1060-MIMXRT1062DVJ6A
Hardware Setup:
- STM32-L432KC – RT1062 (USART1)
- STM32-L432KC – RF module (USART2)
Intent: I am trying to use the stm32 to send a capture command to the camera. The camera then sends chunks of data over UART to the stm32. the stm32 adds some meta data and send its over RF. Another module running on a host PC tacks the binary image data from the RF link and reconstructs the image.
Problem
ideally I would like to use SPI. What is the easiest way to use SPI on the RT1062? As I understand, it cannot use the pyb library (not an stm23 based module)
with my basic UART test, does my camera script look reasonable? I cannot seem to get the UART data to place nice with the stm32 in my setup. Is it possible I am not accessing the recently captured image from the SD card as expected? Has the camera not passed it from internal memory to the SD by the time I am accessing it?
Camera script:
import sensor, image, time, os
#==== hardware UART UART(1) || VCP on UART(3) ====
# Change baudrate/timeouts to match your PC environment.
uart = UART(1, baudrate=9600, timeout=10000) # start slow for testing
# Keep track of the last snapped image filename
LAST_FILENAME = None
def capture_image():
Perform a camera snapshot and save it to a file named with the current
millisecond timestamp. Then reply 'SNAP OK' or 'SNAP FAIL'.
global LAST_FILENAME
print("[Debug] capture_image() called: starting snapshot...")
sensor.set_quality(50)
#sensor.set_auto_gain(False)
#sensor.set_auto_exposure(False)
#sensor.set_auto_whitebal(False)
#sensor.set_lens_correction(True, 50, 80)
sensor.skip_frames(time=1000)
# Snap
# Generate a filename
filename = "snapshot_{}.jpg".format(time.ticks_ms())
img.save(filename)
LAST_FILENAME = filename
# Confirm success
print("[Debug] SNAP OK - Image saved as:", filename)
uart.write(b"SNAP OK\r\n")
except Exception as e:
print("[Debug] SNAP FAIL:", e)
uart.write(b"SNAP FAIL\r\n")
def chunk_image():
Send back the size of the last snapped image, then stream the raw bytes.
Finally, send a DONE line. If no image has been snapped, SIZE=0 + DONE.
print("[Debug] chunk_image() called...")
if not LAST_FILENAME:
print("[Debug] No snapped image yet; sending SIZE 0 + DONE.")
uart.write(b"SIZE 0\r\n")
uart.write(b"DONE\r\n")
return
filesize = os.stat(LAST_FILENAME)[6]
# Build the size line
size_line = "SIZE {}\r\n".format(filesize)
# Print exactly what we're sending for debugging
print(f"[Debug] chunk_image() sending line: {repr(size_line)}")
# Send "SIZE NNN\r\n"
uart.write(size_line.encode())
time.sleep_ms(50) # optional short delay before sending the file data
print("[Debug] Sending file:", LAST_FILENAME, "Size:", filesize)
# --- Added debug chunk counter here ---
chunk_count = 0
with open(LAST_FILENAME, 'rb') as f:
chunk = f.read(1024)
if not chunk:
break
chunk_count += 1
# Debug line to show each chunk's number and length
print(f"[Debug] chunk #{chunk_count}, len={len(chunk)}")
uart.write(chunk)
print(f"[Debug] Done sending file data. Total chunks sent: {chunk_count}")
print("[Debug] CHUNK error:", e)
# Fallback
def main_loop():
Continuously listen for commands:
SNAP -> capture_image()
CHUNK -> chunk_image()
otherwise -> UNKNOWN COMMAND
print("[Debug] main_loop started: listening for commands on UART(1)...")
cmd_buffer = b""
if uart.any():
data = uart.read(uart.any())
if data:
cmd_buffer += data
if b"\n" in cmd_buffer:
lines = cmd_buffer.split(b"\n")
# Process all complete lines
for line in lines[:-1]:
line = line.strip()
if line == b"SNAP":
print("[Debug] Received 'SNAP' command.")
capture_image()
elif line == b"CHUNK":
print("[Debug] Received 'CHUNK' command.")
chunk_image()
print("[Debug] Unknown command:", line)
uart.write(b"UNKNOWN COMMAND\r\n")
# Keep any partial leftover
cmd_buffer = lines[-1]
time.sleep_ms(100) # slight delay for CPU relief
if __name__ == "__main__":
main_loop()
Camera Serial Terminal Debugs (UART(3))
[Debug] main_loop started: listening for commands on UART(1)…
[Debug] Received ‘SNAP’ command.
[Debug] capture_image() called: starting snapshot…
[Debug] SNAP OK - Image saved as: snapshot_511462.jpg
[Debug] Received ‘CHUNK’ command.
[Debug] chunk_image() called…
[Debug] chunk_image() sending line: ‘SIZE 2501\r\n’
[Debug] Sending file: snapshot_511462.jpg Size: 2501
[Debug] chunk #1, len=1024
[Debug] chunk #2, len=1024
[Debug] chunk #3, len=453
[Debug] Done sending file data. Total chunks sent: 3
Output on the RF data link
