Hey, i am using this code to send data to firebase from portenta h7 but getting this error.
b’HTTP/1.1 400 Bad Request\r\nServer: nginx\r\nDate: Tue, 18 Apr 2023 15:02:30 GMT\r\nContent-Type: text/html\r\nContent-Length: 150\r\nConnection: close\r\nStrict-Transport-Security: max-age=31556926; includeSubDomains; preload\r\n\r\n\r\n400 Bad Request\r\n\r\n
400 Bad Request
\r\nnginx\r\n\r\n\r\n’
on this code
import usocket as socket
import json
Connect to Wi-Fi
SSID=‘’ # Network SSID
KEY=‘’ # Network key
sta_if = network.WLAN(network.STA_IF)
if not sta_if.isconnected():
print(‘Connecting to Wi-Fi…’)
sta_if.active(True)
sta_if.connect(SSID, KEY)
while not sta_if.isconnected():
print(‘Connected to Wi-Fi:’, sta_if.ifconfig())
Firebase credentials
firebase_host = ‘’
firebase_secret = ‘’ # replace with your Firebase secret
Data to be sent
data = {‘name’: ‘John Doe’, ‘age’: 30}
Send data to Firebase
url = ‘https://{firebase_host}/data.json?auth={firebase_secret}’.format(
firebase_host=firebase_host, firebase_secret=firebase_secret)
headers = {‘Content-Type’: ‘application/json’}
payload = json.dumps(data)
sock = socket.socket()
addr = socket.getaddrinfo(firebase_host, 443)[0][-1]
sock.connect(addr)
sock.send(b"POST /data.json HTTP/1.0\r\n")
sock.send(b"Host: %s\r\n" % firebase_host.encode(‘utf-8’))
sock.send(b"Content-Length: %d\r\n" % len(payload))
sock.send(b"Content-Type: application/json\r\n")
sock.send(b"\r\n")
sock.send(payload.encode(‘utf-8’))
response = sock.recv(4096)
sock.close()
print(response)
