I’m using an OpenMV cam h7 r2 for a person in/out counter project, the system was trained with edge impulse and it kinda works but now I want to send some data (for example the variable counter “person_in” or a piece of information inside the serial terminal ) from my OpenMW IDE to a local database.
My objective is to show trough a site how many people got in/out from the building.
Any tips for this? I was thinking to send the data from the OpenMW IDE to another python script, and then from there I can send my data with the MySQL library, but I don’t know if it’s the right way.
My OpenMW cam is connected trough USB, I don’t have the wi-fi module.
Thanks.
You just save the script to the camera and then print when something happens.
This part is already done, the script is loaded inside the cam and in the serial terminal I print the variables “person_in” and “person_out”.
You can open the camera serial port on the PC and see print data output with a low amount of effort.
Sorry but just to be clear you mean reading directly the serial monitor with another script outside the OpenMW IDE?
In the mean time I’ve found the WebServerAPI wich maybe it’s what I need, I’ll try with that too.
Ok, so I load my program into the board and execute it without the OpenMW IDE and read the serial with another program.
I know how to load the firmware of my solution and execute the program but how can I do it without the IDE?
