Running long time stops without throwing any exceptions. based on version 4.4.2
I have conducted multiple tests, and the maximum continuous running time is generally no more than one day, usually between 12 to 16 hours. Strangely, the IDE does not throw any exceptions, making it difficult to analyze what caused the program to stop. Has anyone else encountered this issue? How can it be resolved?
That firmware is out of date. There have been many bug fixes since then.
Thank you for your answer. If I want to merge my current code with a relatively stable version, which one do you recommend?
The latest code base is stable now. We’ve finished the ROMFS upgrade and everything is working. However, file names for built in models have changed.
