RT1062 board + GenX320 sensor
Hello, I have several questions related to the GenX320 module:
  • I am interested in combining it with the RT1062 board, do you confirm they are compatible?
  • It seems the RT1062 comes with a regular image sensor module included, is there a way to buy just the RT1062 board?
  • I’m considering to also pre-order a few N6 + AE3 boards, can you confirm they will be compatible with the GenX320 sensor module?
  • I plan to make recordings of several minutes long from the GenX320, the amount of data will quickly add up, and so I will need to rely on external memory. Are there any particular limitations in maximum storage size or bandwidth with the RT1062 board?
    Many thanks!
Yes
Yes, but, you’d have to order a production batch (> 1K). Otherwise, it’s not something we can easily do.
The N6 is compatible. The AE3 doesn’t accept other sensors.
It supports up to 2 TB SDXC cards easily.
