I’m just getting started with the RPC library, and got the “image transfer as jpg” example running in no time.
I’m referring to these scripts:
rpc_image_transfer_jpg_as_the_controller_device.py (for the controler / host computer)
and
image_transfer_jpg_as_the_remote_device_for_your_computer.py (for the openMV camera)
BUT…
When trying the rpc_popular_features_as_the_controller_device_example.py (and the corresponding code for the camera), no matter what callback I select, I would always get an empty frame; and no jpg image was saved.
With the camera still connected, if I run again the jpg image transfer script (that is, copy the proper code on the camera and run the corresponding code on the computer), I could see the live image all-right. Switching back and forth between both examples only the jpg image transfer would show an image, the other example (popular_features …) would give nothing but empty frames.
After spending a long hour digging in the code, making sure I do save the proper code on the camera, adding debug lines in both the camera and computer codes, I thought I could try to unmount the camera (well, technically, its drive), and power cycle it.
Then, magic, everything worked with the rpc_popular_features_as_the_controller_device_example.py script.
So… why do I need to power cycle my board (tested was an H7 R1) in one case but not the other?
Is there another way to avoid a “hard” power cycle (unplug / plug the board)?
