Hello
I’m having problems cloning the OpenMV repository. I keep getting the following error messages:
Cloning into ‘openmv’…
remote: Enumerating objects: 325, done.
remote: Counting objects: 100% (325/325), done.
remote: Compressing objects: 100% (237/237), done.
error: RPC failed; curl 56 GnuTLS recv error (-9): A TLS packet with unexpected length was received.
error: 674 bytes of body are still expected
fatal: the remote end hung up unexpectedly
fatal: early EOF
fatal: index-pack failed
At first I thought it must be my network or git installlation. I have tried switching to my wired network but still the same problems. I have tried cloning the Micropython repository and there is no problem at all with that it cloned fine with that and also the AprilRobotics apriltag repository and those both cloned fine.
I am wondering if there is so problem with there is a problem with a file in the OpenMV repository that is causing the clone to fail ?
Ed
