I am using the example code sensor_exposure_control.py
# Sensor Exposure Control
# This example shows off how to control the camera sensor's
# exposure manually versus letting auto exposure control run.
# What's the difference between gain and exposure control?
# Well, by increasing the exposure time for the image you're getting more
# light on the camera. This gives you the best signal to noise ratio. You
# in general always want to increase the expsoure time... except, when you
# increase the exposure time you decrease the maximum possible frame rate
# and if anything moves in the image it will start to blur more with a
# higher exposure time. Gain control allows you to increase the output per
# pixel using analog and digital multipliers... however, it also amplifies
# noise. So, it's best to let the exposure increase as much as possible
# and then use gain control to make up any remaining ground.
import sensor, image, time
# Change this value to adjust the exposure. Try 10.0/0.1/etc.
EXPOSURE_TIME_SCALE = 1.0
# Print out the initial exposure time for comparison.
print("Initial exposure == %d" % sensor.get_exposure_us())
# You have to turn automatic gain control and automatic white blance off
# otherwise they will change the image gains to undo any exposure settings
# that you put in place...
sensor.set_auto_gain(False)
# Need to let the above settings get in...
sensor.skip_frames(time = 500)
current_exposure_time_in_microseconds = sensor.get_exposure_us()
print("Current Exposure == %d" % current_exposure_time_in_microseconds)
# Auto exposure control (AEC) is enabled by default. Calling the below function
# disables sensor auto exposure control. The additionally "exposure_us"
# argument then overrides the auto exposure value after AEC is disabled.
sensor.set_auto_exposure(False, \
exposure_us = int(current_exposure_time_in_microseconds * EXPOSURE_TIME_SCALE))
print("New exposure == %d" % sensor.get_exposure_us())
# sensor.get_exposure_us() returns the exact camera sensor exposure time
# in microseconds. However, this may be a different number than what was
# commanded because the sensor code converts the exposure time in microseconds
# to a row/pixel/clock time which doesn't perfectly match with microseconds...
# If you want to turn auto exposure back on do: sensor.set_auto_exposure(True)
# Note that the camera sensor will then change the exposure time as it likes.
# Doing: sensor.set_auto_exposure(False)
# Just disables the exposure value update but does not change the exposure
# value the camera sensor determined was good.
I have two different sensors, the Global Shutter Camera and an IR Sensor.
I want to measure the exposure time and the frames per second (FPS). As can be seen in the Terminal, I have the following results:
Global Shutter
Exposure = 17031
FPS = 33.33333
IR Sensor
Exposure = 805325451
FPS = 8.403361
Here there is a difference between both sensors and it makes the IR Sensor seems wrong.
Do you know why and what is the problem?
Thank you!
