Hi there,
something strange is happening to my camera with h7 with global shutter attached.
when i try to set the exposure and gain at:
sensor.set_auto_gain(False)
sensor.set_auto_exposure(False,22500)
i get 48 fps
but when i try to reduce the exposure time at:
sensor.set_auto_exposure(False,2500)
i take 30 fps.
Why i get higher fps when i have more exposure than when i reduce it?
I think you need to pass sensor.set_auto_exposure(False,exposure_us=2500)
Otherwise it’s not looking at the exposure value and you’re just locking in whatever the lighting is.
i did tried your solution with same results.
in fact this isn’t true. the value just pass fine without the “exposure_us” but i added.
If it isn’t problem for you it isn’t for me too…
This post is just for feedback… you can try it yourself too! i have 3 cameras all with the same behaviour
This is what the code is doing: https://github.com/openmv/openmv/blob/master/src/omv/mt9v034.c#L273
Looks like I automatically grab the exposure without needing the keyword. https://github.com/openmv/openmv/blob/master/src/omv/py/py_sensor.c#L390
Note sure why this happens. Does the image have more exposure however?
