I have been using the Rt1062. The OpenMV IDE has been working fine. However, after a system update (Dell), whenever I connect the camera in the IDE, the IDE becomes slow, even without running any code.
- I am using windows 11
- When disconnecting the camera from the IDE, it returns to normal.
- I looked up my problem in the forums but didn’t find anything.
- I tried erasing the onboard data flash, but it didn’t fix the problem.
- I made sure I have the latest development installed.
- I removed the (empty) SD card, and it was still slow.
- I restarted the PC as well. I did not change the USB port that I was using to connect the camera.
This problem has happened before but it fixed itself when I restarted the PC. However, it is different this time.
Any help would be appreciated. Thanks in advance.
