OpenMV H7 Plus produvts
Hello, I’m using the OpenMV H7 Plus and I want to use the official 1.8-inch LCD screen together with the OpenMV WiFi expansion module (ATWINC1500). Will there be a pin conflict? Can the conflict be avoided。
Hi, they both use the SPI bus pins, so, you can only use one or the other. The RT1062 and N6 have wifi onboard which solves this problem.
