Same here.
When selecting “Ignore”, the installation runs through without any further errors (at least for me).
Though, no idea what exactly I’m ignoring with this
It’s not an issue for most things as that’s just the certs for Arduino Boards. If you install the Arduino IDE it installs that.
Can you help me debug this issue? I’ll post the command I need you to run so I can get the error code in a bit. You can manually run the installer that it tried to execute and I should be able to figure out what’s wrong.
I have to use cmd /k otherwise the console window just closes.
If I run the above in a console, Windows asks me for permission to run the “Driver Package Installer”. Once I approve this, it just returns to the prompt.
