Hi all, am just starting on open mv H7 and decided to train a simple model on edge impulse… I got this error when running the model on openmv cam… How can I go about it?.. Thanks
If you have a model for the OpenMV Cam H7 then you should not use larger than a 48x48 pixel input network. The default Edge Impulse network is 96x96 pixels which will produce a model that is too big.
