Hi all,
I have an instable processing on a RT10162 with the NOR flash. It fall down in the DTU mode and now when I try to manually reflash the bootloader, I’m stoppend by this command :
blhost -u 0x15A2,0x0073 – configure-memory 9 0x2000
Response status = 20107 (0x4e8b) FlexSPINOR: SFDP Not Found.
Any idea are welcome !
HI,
Thanks for your answer.
I started the process from the 14.1.1.6 doc. In the second command of the third step (blhost -u 0x15A2,0x0073 – configure-memory 9 0x2000), the return always the same : Response status = 20107 (0x4e8b) FlexSPINOR: SFDP Not Found. All initial commands are executed successfully.
Could a replacement could be considered ?
Was the unit working when you received it? You shouldn’t have had to update the bootloader at all.
