Nicla Vision's IMU not working
Hi
(Yes, me gain… it seems that everything just don’t want to work with the Nicla vision)
I’am working on a project with an MCP2515 which work only with the 4.3.3 firmware and developpment release. It’s about an SPI issue that seems solved after this release.
But I also need the IMU and it give me constant dumb values (3872.77, 505.812, 5972.88) for the acceleration. No matter how I shake the board.
It seems to work only with the 4.3.1 NICLAV firmware release but I need to use the MCP2515 on a newer release.
This is the non working code :
import time, imu
    time.sleep(0.5)
    print(imu.acceleration_mg())
imu.sleep(True)
Thank you if anyone can share a solution.
I saw your issue on github, will get around to testing and fixing it soon.
Ok, thank you.
Fixed
