I used the Nicla Vision on the Arduino IDE first and worked perfectly. Now that I want to use it on the OpenMV IDE it doesn’t connect. I haven’t used the Nicla Vision on the OpenMV IDE before.
What I’m doing is this:
Double clicking on the reset button, Nicla Vision starts blinking in a green tone.
Clicking on the connect image in the OpenMV IDE
Trying to connect and the loading lasts for more than 5s
Hit cancel
Message appears “Error: A peripheral attached to the system doesn’t work correctly!”
I wasn’t even able to connect the Nicla Vision to the OpenMV IDE, but I was able to connect it to the Arduino IDE and install Arduino mbed Core and other libraries.
Right now, I can’t connect at all the Nicla Vision to the OpenMV IDE. There’s only the USB logo that appears and the when I click on it, it loads indefinitly.
Hi, you need to install Arduinos IDE and then install the nicla mbed board package.
If you check your device manager what’s likely missing is the driver for DFU mode. I have to add to is to be installed by OpenMV IDE. We only install the Portenta driver right now.
If we are using the same driver as the Portenta vision shield, any chance we could use the himax sensor from that board with the Nicla Vision board? Are they the same mipi csi2 connectors?
