I am attempting to create a robot controlled by buttons on a web page served by a nicla vision.
I have set the nicla as a server in ap mode which creates a web page with streamed video and buttons to control the wheel motors.
As an initial test I have used the streaming sketch in openmv and added some buttons to the html . The buttons have been programmed to turn the blue LED on and off
The web page displays correctly as a streamed video window with 2 buttons displayed beneath.
All works until I press a button. The server disconnects briefly and only on reconnecting does the button press get processed. This can take several seconds. Is there a better way to receive data from the client. At present I have put the
client.recv(1024)
function inside the start_streaming(client) function.
Program
# MJPEG Streaming AP.
# This example shows off how to do MJPEG streaming in AccessPoint mode.
# Chrome, Firefox and MJpegViewer App on Android have been tested.
# Connect to OPENMV_AP and use this URL: http://192.168.1.1:8080 to view the stream.
import sensor
import socket
from machine import LED, Pin
SSID = "OPENMV_AP" # Network SSID
KEY = "1234567890" # Network key (must be 10 chars)
HOST = "" # Use first available interface
PORT = 8080 # Arbitrary non-privileged port
# Reset sensor
# Init wlan module in AP mode.
wlan = network.WLAN(network.AP_IF)
wlan.config(ssid=SSID, key=KEY, channel=2)
print("AP mode started. SSID: {} IP: {}".format(SSID, wlan.ifconfig()[0]))
# You can block waiting for client to connect
# print(wlan.wait_for_sta(100000))
led = LED("LED_BLUE") # Initialize LED (LED(1) is usually the red LED on the OpenMV Cam)
def start_streaming(client):
# Send HTML page with control buttons
html = (
"HTTP/1.1 200 OK\r\n"
"Content-Type: text/html\r\n"
"Connection: close\r\n"
"\r\n"
"<html><head><title>OpenMV Cam</title></head><body>"
"<form>"
#"<button type=\"submit\" name=\"led\" value=\"on\">LED On</button>"
#"<button type=\"submit\" name=\"led\" value=\"off\">LED Off</button>"
"<button name=\"On\" type=\"submit\" value=\"On\">On</button>"
"<button name=\"Off\" type=\"submit\" value=\"Off\">Off</button>"
"</form>"
"<h1>MJPEG Stream</h1>"
"<img src=\"/stream\" style=\"width: 100%; max-width: 320px;\" />"
"<h2>Control LED</h2>"
"</body></html>"
if "/stream" in data:
# Send multipart header
client.send(
"Server: OpenMV\r\n"
"Content-Type: multipart/x-mixed-replace;boundary=openmv\r\n"
"Cache-Control: no-cache\r\n"
"Pragma: no-cache\r\n\r\n"
# FPS clock
# Start streaming images
# NOTE: Disable IDE preview to increase streaming FPS.
frame = sensor.snapshot()
cframe = frame.to_jpeg(quality=35, copy=True)
header = (
"\r\n--openmv\r\n"
"Content-Type: image/jpeg\r\n"
"Content-Length:" + str(cframe.size()) + "\r\n\r\n"
client.sendall(header)
client.sendall(cframe)
# Check if data received from client every sec
delta = time.ticks_diff(time.ticks_ms(),start)
if delta > 1000:
# get data from client
data = client.recv(1024).decode('utf-8')
print(data)
# Parse client request to control LED
if "On" in data:
led.value(1)
elif "Off" in data:
led.value(0)*
# Send HTML page
client.send(html)
client.close()
server = None
if server is None:
# Create server socket
server = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
server.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, True)
# Bind and listen
server.bind([HOST, PORT])
server.listen(5)
# Set server socket to blocking
server.setblocking(True)
print("Waiting for connections..")
client, addr = server.accept()
except OSError as e:
server.close()
server = None
print("server socket error:", e)
# set client socket timeout to 2s
client.settimeout(5.0)
print("Connected to " + addr[0] + ":" + str(addr[1]))
client.close()
print("client socket error:", e)
# sys.print_exception(e)
