jcmag
April 30, 2024, 9:20pm
1
I’m testing the latest 1062 cam. Here is the initialization:
then if I call: sensor.set_contrast(3), or set_contrast(-3), I clearly see the difference in the output image.
But calling sensor.set_saturation(x) or sensor.set_brightness(x) does nothing.
Am I missing something?
Those features are implemented for the OV5640. However, honestly they are kinda obsolete features. I’d avoid using them at all.
ret |= omv_i2c_writeb2(&sensor->i2c_bus, sensor->slv_addr, VFIFO_HSIZE_H, w >> 8);
ret |= omv_i2c_writeb2(&sensor->i2c_bus, sensor->slv_addr, VFIFO_HSIZE_L, w);
ret |= omv_i2c_writeb2(&sensor->i2c_bus, sensor->slv_addr, VFIFO_VSIZE_H, h >> 8);
ret |= omv_i2c_writeb2(&sensor->i2c_bus, sensor->slv_addr, VFIFO_VSIZE_L, h);
return ret;
static int set_contrast(sensor_t *sensor, int level) {
int ret = 0;
int new_level = level + (NUM_CONTRAST_LEVELS / 2);
if (new_level < 0 || new_level >= NUM_CONTRAST_LEVELS) {
return -1;
ret |= omv_i2c_writeb2(&sensor->i2c_bus, sensor->slv_addr, 0x3212, 0x03); // start group 3
ret |= omv_i2c_writeb2(&sensor->i2c_bus, sensor->slv_addr, 0x5586, (new_level + 5) << 2);
ret |= omv_i2c_writeb2(&sensor->i2c_bus, sensor->slv_addr, 0x5585, contrast_regs[new_level][0]);
ret |= omv_i2c_writeb2(&sensor->i2c_bus, sensor->slv_addr, 0x3212, 0x13); // end group 3
ret |= omv_i2c_writeb2(&sensor->i2c_bus, sensor->slv_addr, 0x3212, 0xa3); // launch group 3
return ret;
static int set_brightness(sensor_t *sensor, int level) {
int ret = 0;
int new_level = level + (NUM_BRIGHTNESS_LEVELS / 2);
if (new_level < 0 || new_level >= NUM_BRIGHTNESS_LEVELS) {
return -1;
ret |= omv_i2c_writeb2(&sensor->i2c_bus, sensor->slv_addr, 0x5587, abs(level) << 4);
ret |= omv_i2c_writeb2(&sensor->i2c_bus, sensor->slv_addr, 0x5588, (level < 0) ? 0x09 : 0x01);
return ret;
static int set_saturation(sensor_t *sensor, int level) {
int ret = 0;
int new_level = level + (NUM_SATURATION_LEVELS / 2);
if (new_level < 0 || new_level >= NUM_SATURATION_LEVELS) {
return -1;
ret |= omv_i2c_writeb2(&sensor->i2c_bus, sensor->slv_addr, 0x5581, 0x1c);
ret |= omv_i2c_writeb2(&sensor->i2c_bus, sensor->slv_addr, 0x5582, 0x5a);
We followed the reference manual on implementation. But, they are basically useless. You want to use auto gain control, and auto exposure control.
Try this out if you want to boost the camera image: Spot in image (not homogeneous) - #9 by kwagyeman
Will probably merge something like this into main soon since it improves the image quality. However, it’s not quite there yet.
jcmag
May 1, 2024, 11:13am
4
it’s a little better, thanks
jcmag
May 21, 2024, 1:04pm
5
what about sensor.set_auto_exposure with the new 1062 cam? when I set it to true, if the light decreases, the image goes very dark, and printing: print(f"exposure: {sensor.get_exposure_us()}") always return 57200, as if set_auto_exposure(true) didn’t work…
jcmag
May 21, 2024, 3:22pm
6
2nd question, I’m trying to adjust the exposure in my code:
import sensor, image, time
sensor.set_auto_exposure(False, exposure_us=57200*1)
sensor.set_auto_gain(False)
sensor.skip_frames(time = 500)
min_exposure_us = 57200
max_exposure_us = 57200 * 10
target_brightness = 20
tolerance = 4
exposure_step = 57200
stats = img.get_statistics()
brightness = stats[0]
img.draw_string(0, 0, "Brightness: %.2f" % brightness, color=(255, 255, 255))
img.draw_string(0, 10, "Exposure: %d us" % sensor.get_exposure_us(), color=(255, 255, 255))
if brightness < target_brightness - tolerance:
exposure_us = sensor.get_exposure_us()
if exposure_us < max_exposure_us:
sensor.set_auto_exposure(False, exposure_us=min(exposure_us + exposure_step, max_exposure_us))
elif brightness > target_brightness + tolerance:
if exposure_us > min_exposure_us:
sensor.set_auto_exposure(False, exposure_us=max(exposure_us - exposure_step, min_exposure_us))
print(f"clock: {clock.avg()} ms")
img.draw_string(240, 0, "%.2f ms" % clock.avg(), color=(255, 255, 255))
The change of exposure works, but what is weird is that clock.avg() keeps increasing, even when there is no more light change (so " if brightness < target_brightness - tolerance:" and the elif are not called anymore)
If I put both “sensor.set_auto_exposure” calls in comments, the clock.avg is constant (but of course the exposure doesn’t change)
I don’t understand what’s happening…
Yeah, the camera will lower the exposure to increase the gain.
However, given what I discovered with the lens correction registers I think the camera brightness can be improved by turning lens correction back on. I just haven’t had time to work on this.
The average can move rather slowly, sometimes to its final value. We use a running average that doesn’t drop old samples. So, if the initial values are widely different from the final then it will take a while for the average to remove the bias of the original samples.
