Sorry to be the bearer of firmware problems I know you must be very busy…However, please can you look at the sensor.IOCTL_SET_READOUT_WINDOW. I am using it for Digital PTZ, but it seems to have stopped working properly. It fails in both the examples in the latest firmware as well…
Thanks I will try that, but I think there are other problems.
# Hello World Example
import sensor, image, time
print ("Setup Cam")
sensor.set_gainceiling(128)
print ("Set auto gain")
sensor.set_auto_gain(True)
print ("Set auto exposure")
sensor.set_auto_exposure(True)
print ("Set framesize")
sensor.set_framesize(sensor.HD)
print ("Set pixformat")
print ("Set framerate")
sensor.set_framerate(1)
print ("Set buffers")
sensor.set_framebuffers(8)
# Reset and initialize the sensor.
#sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE)
#sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240)
This stalls at the sensor.set_pixformat, but only if the set framerate is run. If you comment out set framerate and buffers it runs…
I think there may be others, but I will have to track them down.
Yes there was another crash in my code, but it appears to be just further instances of set_framerate. When they are all commented out, all is well again…
Please run the modified hello world sample below. I have added an LED to be sure below.
It never reaches the main loop. The USB disconnects and the LED flashing does not occur.
(However if you remove the set_framerate and set_framebuffers lines it does work.)
So there is a new problem with set_framerate (I believe, though it may be the set_framebuffers) but it is quite difficult to tell which line as the USB print seems to be lost in buffering when the USB disconnects.
from pyb import LED
red_led = LED(1)
green_led = LED(2)
blue_led = LED(3)
ir_led = LED(4)
def led_control(x):
if (x&1)==0: red_led.off()
elif (x&1)==1: red_led.on()
if (x&2)==0: green_led.off()
elif (x&2)==2: green_led.on()
if (x&4)==0: blue_led.off()
elif (x&4)==4: blue_led.on()
if (x&8)==0: ir_led.off()
elif (x&8)==8: ir_led.on()
print ("Setup Cam")
led_control(1)
led_control(0)
led_control(1)
pyb.delay(100)
led_control(0)
pyb.delay(100)
