N6 IR sensitivity/cut filter?
Hi! I can’t find any info on this, but will the N6 have a removable Ir cut filter?
No, it won’t be removable, but, we’ve stocked all types of lenses in the store for you: OpenMV Cam Lenses
IR and non-IR are both in stock, so, we have whatever you need covered.
The lenses used to have the IR filter glued to the back, but, the manufacturer makes them with the IR filter integrated into the lens assembly now.
Gotcha, so the sensor itself is IR sensitive?
Yes, it is. All CMOS sensors are.
