- * This file is part of the OpenMV project.
- * Copyright (c) 2013-2021 Ibrahim Abdelkader <iabdalkader@openmv.io>
- * Copyright (c) 2013-2021 Kwabena W. Agyeman <kwagyeman@openmv.io>
- * This work is licensed under the MIT license, see the file LICENSE for details.
- * Board configuration and pin definitions.
- #ifndef __OMV_BOARDCONFIG_H__
- #define __OMV_BOARDCONFIG_H__
- // Architecture info
- #define OMV_ARCH_STR "OMV4P H7 32768 SDRAM" // 33 chars max
- #define OMV_BOARD_TYPE "H7"
- #define OMV_UNIQUE_ID_ADDR 0x1FF1E800
- #define OMV_UNIQUE_ID_SIZE 3 // 3 words
- // Needed by the SWD JTAG testrig - located at the bottom of the frame buffer overlay stack.
- #define OMV_SELF_TEST_SWD_ADDR *((uint32_t *) 0x24000018)
- #define OMV_XCLK_MCO (0U)
- #define OMV_XCLK_TIM (1U)
- // Sensor external clock source.
- #define OMV_XCLK_SOURCE (OMV_XCLK_TIM)
- // Sensor external clock timer frequency.
- #define OMV_XCLK_FREQUENCY (12000000)
- // Sensor PLL register value.
- #define OMV_OV7725_PLL_CONFIG (0x41) // x4
- // Sensor Banding Filter Value
- #define OMV_OV7725_BANDING (0x7F)
- // OV5640 Sensor Settings
- #define OMV_OV5640_XCLK_FREQ (24000000)
- #define OMV_OV5640_PLL_CTRL2 (0x64)
- #define OMV_OV5640_PLL_CTRL3 (0x13)
- #define OMV_OV5640_REV_Y_CHECK (1)
- #define OMV_OV5640_REV_Y_FREQ (25000000)
- #define OMV_OV5640_REV_Y_CTRL2 (0x54)
- #define OMV_OV5640_REV_Y_CTRL3 (0x13)
- // Enable hardware JPEG
- #define OMV_HARDWARE_JPEG (1)
- // Enable MDMA sensor offload.
- #define OMV_ENABLE_SENSOR_MDMA (1)
- // Enable sensor drivers
- #define OMV_ENABLE_OV2640 (1)
- #define OMV_ENABLE_OV5640 (1)
- #define OMV_ENABLE_OV7690 (0)
- #define OMV_ENABLE_OV7725 (1)
- #define OMV_ENABLE_OV9650 (1)
- #define OMV_ENABLE_MT9M114 (1)
- #define OMV_ENABLE_MT9V0XX (1)
- #define OMV_ENABLE_LEPTON (1)
- #define OMV_ENABLE_HM01B0 (0)
- #define OMV_ENABLE_PAJ6100 (1)
- #define OMV_ENABLE_FROGEYE2020 (1)
- // Enable sensor features
- #define OMV_ENABLE_OV5640_AF (0)
- // Enable WiFi debug
- #define OMV_ENABLE_WIFIDBG (1)
- // Enable self-tests on first boot
- #define OMV_ENABLE_SELFTEST (1)
- // If buffer size is bigger than this threshold, the quality is reduced.
- // This is only used for JPEG images sent to the IDE not normal compression.
- #define JPEG_QUALITY_THRESH (1920*1080*2)
- // Low and high JPEG QS.
- #define JPEG_QUALITY_LOW 50
- #define JPEG_QUALITY_HIGH 90
- // FB Heap Block Size
- #define OMV_UMM_BLOCK_SIZE 256
- // Core VBAT for selftests
- #define OMV_CORE_VBAT "3.3"
- // USB IRQn.
- #define OMV_USB_IRQN (OTG_FS_IRQn)
- //PLL1 48MHz for USB, SDMMC and FDCAN
- #define OMV_OSC_PLL1M (3)
- #define OMV_OSC_PLL1N (240)
- #define OMV_OSC_PLL1P (2)
- #define OMV_OSC_PLL1Q (20)
- #define OMV_OSC_PLL1R (2)
- #define OMV_OSC_PLL1VCI (RCC_PLL1VCIRANGE_2)
- #define OMV_OSC_PLL1VCO (RCC_PLL1VCOWIDE)
- #define OMV_OSC_PLL1FRAC (0)
- // PLL2 200MHz for FMC and QSPI.
- #define OMV_OSC_PLL2M (3)
- #define OMV_OSC_PLL2N (100)
- #define OMV_OSC_PLL2P (2)
- #define OMV_OSC_PLL2Q (2)
- #define OMV_OSC_PLL2R (2)
- #define OMV_OSC_PLL2VCI (RCC_PLL2VCIRANGE_2)
- #define OMV_OSC_PLL2VCO (RCC_PLL2VCOWIDE)
- #define OMV_OSC_PLL2FRAC (0)
- // PLL3 160MHz for ADC and SPI123
- #define OMV_OSC_PLL3M (3)
- #define OMV_OSC_PLL3N (80)
- #define OMV_OSC_PLL3P (2)
- #define OMV_OSC_PLL3Q (2)
- #define OMV_OSC_PLL3R (2)
- #define OMV_OSC_PLL3VCI (RCC_PLL3VCIRANGE_2)
- #define OMV_OSC_PLL3VCO (RCC_PLL3VCOWIDE)
- #define OMV_OSC_PLL3FRAC (0)
- // Clock Sources
- #define OMV_OSC_PLL_CLKSOURCE RCC_PLLSOURCE_HSE
- #define OMV_OSC_USB_CLKSOURCE RCC_USBCLKSOURCE_HSI48
- #define OMV_OSC_RNG_CLKSOURCE RCC_RNGCLKSOURCE_HSI48
- #define OMV_OSC_ADC_CLKSOURCE RCC_ADCCLKSOURCE_PLL3
- #define OMV_OSC_SPI123_CLKSOURCE RCC_SPI123CLKSOURCE_PLL3
- // HSE/HSI/CSI State
- #define OMV_OSC_HSE_STATE (RCC_HSE_ON)
- #define OMV_OSC_HSI48_STATE (RCC_HSI48_ON)
- // Flash Latency
- #define OMV_FLASH_LATENCY (FLASH_LATENCY_2)
- // Power supply configuration
- #define OMV_PWR_SUPPLY (PWR_LDO_SUPPLY)
- // Linker script constants (see the linker script template stm32fxxx.ld.S).
- // Note: fb_alloc is a stack-based, dynamically allocated memory on FB.
- // The maximum available fb_alloc memory = FB_ALLOC_SIZE + FB_SIZE - (w*h*bpp).
- #define OMV_MAIN_MEMORY SRAM1 // data, bss and heap
- #define OMV_STACK_MEMORY ITCM // stack memory
- #define OMV_DMA_MEMORY SRAM3 // Misc DMA buffers memory.
- #define OMV_FB_MEMORY DRAM // Framebuffer, fb_alloc
- #define OMV_JPEG_MEMORY DRAM // JPEG buffer memory buffer.
- #define OMV_JPEG_MEMORY_OFFSET (31M) // JPEG buffer is placed after FB/fballoc memory.
- #define OMV_VOSPI_MEMORY SRAM4 // VoSPI buffer memory.
- #define OMV_FB_OVERLAY_MEMORY AXI_SRAM // Fast fb_alloc memory.
- #define OMV_FB_OVERLAY_MEMORY_OFFSET (496*1024) // Fast fb_alloc memory size.
- #define OMV_FB_SIZE (20M) // FB memory: header + VGA/GS image
- #define OMV_FB_ALLOC_SIZE (11M) // minimum fb alloc size
- #define OMV_STACK_SIZE (64K)
- #define OMV_HEAP_SIZE (240K)
- #define OMV_SDRAM_SIZE (32 * 1024 * 1024) // This needs to be here for UVC firmware.
- #define OMV_LINE_BUF_SIZE (11 * 1024) // Image line buffer round(2592 * 2BPP * 2 buffers).
- #define OMV_MSC_BUF_SIZE (2K) // USB MSC bot data
- #define OMV_VFS_BUF_SIZE (1K) // VFS sturct + FATFS file buffer (624 bytes)
- #define OMV_FIR_LEPTON_BUF_SIZE (1K) // FIR Lepton Packet Double Buffer (328 bytes)
- #define OMV_JPEG_BUF_SIZE (1024*1024) // IDE JPEG buffer (header + data).
- #define OMV_TEXT_ORIGIN 0x08040000
- #define OMV_TEXT_LENGTH 1792K
- #define OMV_DTCM_ORIGIN 0x20000000 // Note accessible by CPU and MDMA only.
- #define OMV_DTCM_LENGTH 128K
- #define OMV_ITCM_ORIGIN 0x00000000
- #define OMV_ITCM_LENGTH 64K
- #define OMV_SRAM1_ORIGIN 0x30000000
- #define OMV_SRAM1_LENGTH 256K // SRAM1 + SRAM2 + 1/2 SRAM3
- #define OMV_SRAM3_ORIGIN 0x30040000
- #define OMV_SRAM3_LENGTH 32K
- #define OMV_SRAM4_ORIGIN 0x38000000
- #define OMV_SRAM4_LENGTH 64K
- #define OMV_AXI_SRAM_ORIGIN 0x24000000
- #define OMV_AXI_SRAM_LENGTH 512K
- #define OMV_DRAM_ORIGIN 0xC0000000
- #define OMV_DRAM_LENGTH 32M
- // Domain 1 DMA buffers region.
- #define OMV_DMA_MEMORY_D1 AXI_SRAM
- #define OMV_DMA_MEMORY_D1_SIZE (16*1024) // Reserved memory for DMA buffers
- #define OMV_DMA_REGION_D1_BASE (OMV_AXI_SRAM_ORIGIN+OMV_FB_OVERLAY_MEMORY_OFFSET)
- #define OMV_DMA_REGION_D1_SIZE MPU_REGION_SIZE_16KB
- // Domain 2 DMA buffers region.
- #define OMV_DMA_MEMORY_D2 SRAM3
- #define OMV_DMA_MEMORY_D2_SIZE (16*1024) // Reserved memory for DMA buffers
- #define OMV_DMA_REGION_D2_BASE (OMV_SRAM3_ORIGIN+(0*1024))
- #define OMV_DMA_REGION_D2_SIZE MPU_REGION_SIZE_32KB
- // Domain 3 DMA buffers region.
- #define OMV_DMA_MEMORY_D3 SRAM4
- #define OMV_DMA_MEMORY_D3_SIZE (64*1024) // Reserved memory for DMA buffers
- #define OMV_DMA_REGION_D3_BASE (OMV_SRAM4_ORIGIN+(0*1024))
- #define OMV_DMA_REGION_D3_SIZE MPU_REGION_SIZE_64KB
- // AXI QoS - Low-High (0:15) - default 0
- #define OMV_AXI_QOS_MDMA_R_PRI 15 // Max pri to move data.
- #define OMV_AXI_QOS_MDMA_W_PRI 15 // Max pri to move data.
- // Image sensor I2C
- #define ISC_I2C (I2C1)
- #define ISC_I2C_ID (1)
- #define ISC_I2C_AF (GPIO_AF4_I2C1)
- #define ISC_I2C_CLK_ENABLE() __I2C1_CLK_ENABLE()
- #define ISC_I2C_CLK_DISABLE() __I2C1_CLK_DISABLE()
- #define ISC_I2C_SCL_PORT (GPIOB)
- #define ISC_I2C_SCL_PIN (GPIO_PIN_8)
- #define ISC_I2C_SDA_PORT (GPIOB)
- #define ISC_I2C_SDA_PIN (GPIO_PIN_9)
- #define ISC_I2C_SPEED (CAMBUS_SPEED_STANDARD)
- #define ISC_I2C_FORCE_RESET() __HAL_RCC_I2C1_FORCE_RESET()
- #define ISC_I2C_RELEASE_RESET() __HAL_RCC_I2C1_RELEASE_RESET()
- /* FIR I2C */
- #define FIR_I2C (I2C2)
- #define FIR_I2C_ID (2)
- #define FIR_I2C_AF (GPIO_AF4_I2C2)
- #define FIR_I2C_CLK_ENABLE() __I2C2_CLK_ENABLE()
- #define FIR_I2C_CLK_DISABLE() __I2C2_CLK_DISABLE()
- #define FIR_I2C_SCL_PORT (GPIOB)
- #define FIR_I2C_SCL_PIN (GPIO_PIN_10)
- #define FIR_I2C_SDA_PORT (GPIOB)
- #define FIR_I2C_SDA_PIN (GPIO_PIN_11)
- #define FIR_I2C_SPEED (CAMBUS_SPEED_FULL)
- #define FIR_I2C_FORCE_RESET() __HAL_RCC_I2C2_FORCE_RESET()
- #define FIR_I2C_RELEASE_RESET() __HAL_RCC_I2C2_RELEASE_RESET()
- /* DCMI */
- #define DCMI_TIM (TIM1)
- #define DCMI_TIM_PIN (GPIO_PIN_8)
- #define DCMI_TIM_PORT (GPIOA)
- #define DCMI_TIM_AF (GPIO_AF1_TIM1)
- #define DCMI_TIM_CHANNEL (TIM_CHANNEL_1)
- #define DCMI_TIM_CLK_ENABLE() __TIM1_CLK_ENABLE()
- #define DCMI_TIM_CLK_DISABLE() __TIM1_CLK_DISABLE()
- #define DCMI_TIM_PCLK_FREQ() HAL_RCC_GetPCLK2Freq()
- #define DCMI_RESET_PIN (GPIO_PIN_10)
- #define DCMI_RESET_PORT (GPIOA)
- #define DCMI_PWDN_PIN (GPIO_PIN_7)
- #define DCMI_PWDN_PORT (GPIOD)
- #define DCMI_FSYNC_PIN (GPIO_PIN_4)
- #define DCMI_FSYNC_PORT (GPIOB)
- #define DCMI_D0_PIN (GPIO_PIN_6)
- #define DCMI_D1_PIN (GPIO_PIN_7)
- #define DCMI_D2_PIN (GPIO_PIN_10)
- #define DCMI_D3_PIN (GPIO_PIN_11)
- #define DCMI_D4_PIN (GPIO_PIN_4)
- #define DCMI_D5_PIN (GPIO_PIN_6)
- #define DCMI_D6_PIN (GPIO_PIN_5)
- #define DCMI_D7_PIN (GPIO_PIN_6)
- #define DCMI_D0_PORT (GPIOC)
- #define DCMI_D1_PORT (GPIOC)
- #define DCMI_D2_PORT (GPIOG)
- #define DCMI_D3_PORT (GPIOG)
- #define DCMI_D4_PORT (GPIOE)
- #define DCMI_D5_PORT (GPIOB)
- #define DCMI_D6_PORT (GPIOE)
- #define DCMI_D7_PORT (GPIOE)
- #define DCMI_HSYNC_PIN (GPIO_PIN_4)
- #define DCMI_VSYNC_PIN (GPIO_PIN_7)
- #define DCMI_PXCLK_PIN (GPIO_PIN_6)
- #define DCMI_HSYNC_PORT (GPIOA)
- #define DCMI_VSYNC_PORT (GPIOB)
- #define DCMI_PXCLK_PORT (GPIOA)
- #define DCMI_RESET_LOW() HAL_GPIO_WritePin(DCMI_RESET_PORT, DCMI_RESET_PIN, GPIO_PIN_RESET)
- #define DCMI_RESET_HIGH() HAL_GPIO_WritePin(DCMI_RESET_PORT, DCMI_RESET_PIN, GPIO_PIN_SET)
- #define DCMI_PWDN_LOW() HAL_GPIO_WritePin(DCMI_PWDN_PORT, DCMI_PWDN_PIN, GPIO_PIN_RESET)
- #define DCMI_PWDN_HIGH() HAL_GPIO_WritePin(DCMI_PWDN_PORT, DCMI_PWDN_PIN, GPIO_PIN_SET)
- #define DCMI_FSYNC_LOW() HAL_GPIO_WritePin(DCMI_FSYNC_PORT, DCMI_FSYNC_PIN, GPIO_PIN_RESET)
- #define DCMI_FSYNC_HIGH() HAL_GPIO_WritePin(DCMI_FSYNC_PORT, DCMI_FSYNC_PIN, GPIO_PIN_SET)
- #define DCMI_VSYNC_EXTI_IRQN (EXTI9_5_IRQn)
- #define DCMI_VSYNC_EXTI_LINE (7)
- #define DCMI_VSYNC_EXTI_GPIO (EXTI_GPIOB)
- #define DCMI_VSYNC_EXTI_SHARED (0)
- #define WINC_SPI (SPI2)
- #define WINC_SPI_AF (GPIO_AF5_SPI2)
- #define WINC_SPI_TIMEOUT (1000)
- // SPI1/2/3 clock source is PLL2 (160MHz/4 == 40MHz).
- #define WINC_SPI_PRESCALER (SPI_BAUDRATEPRESCALER_4)
- #define WINC_SPI_CLK_ENABLE() __HAL_RCC_SPI2_CLK_ENABLE()
- #define WINC_SPI_SCLK_PIN (GPIO_PIN_13)
- #define WINC_SPI_MISO_PIN (GPIO_PIN_14)
- #define WINC_SPI_MOSI_PIN (GPIO_PIN_15)
- #define WINC_SPI_SCLK_PORT (GPIOB)
- #define WINC_SPI_MISO_PORT (GPIOB)
- #define WINC_SPI_MOSI_PORT (GPIOB)
- #define WINC_EN_PIN (GPIO_PIN_5)
- #define WINC_CS_PIN (GPIO_PIN_12)
- #define WINC_RST_PIN (GPIO_PIN_12)
- #define WINC_IRQ_PIN (pin_D13)
- #define WINC_EN_PORT (GPIOA)
- #define WINC_CS_PORT (GPIOB)
- #define WINC_RST_PORT (GPIOD)
- #define WINC_CS_LOW() HAL_GPIO_WritePin(WINC_CS_PORT, WINC_CS_PIN, GPIO_PIN_RESET)
- #define WINC_CS_HIGH() HAL_GPIO_WritePin(WINC_CS_PORT, WINC_CS_PIN, GPIO_PIN_SET)
- #define SOFT_I2C_PORT GPIOB
- #define SOFT_I2C_SIOC_PIN GPIO_PIN_10
- #define SOFT_I2C_SIOD_PIN GPIO_PIN_11
- #define SOFT_I2C_SIOC_H() HAL_GPIO_WritePin(SOFT_I2C_PORT, SOFT_I2C_SIOC_PIN, GPIO_PIN_SET)
- #define SOFT_I2C_SIOC_L() HAL_GPIO_WritePin(SOFT_I2C_PORT, SOFT_I2C_SIOC_PIN, GPIO_PIN_RESET)
- #define SOFT_I2C_SIOD_H() HAL_GPIO_WritePin(SOFT_I2C_PORT, SOFT_I2C_SIOD_PIN, GPIO_PIN_SET)
- #define SOFT_I2C_SIOD_L() HAL_GPIO_WritePin(SOFT_I2C_PORT, SOFT_I2C_SIOD_PIN, GPIO_PIN_RESET)
- #define SOFT_I2C_SIOD_READ() HAL_GPIO_ReadPin (SOFT_I2C_PORT, SOFT_I2C_SIOD_PIN)
- #define SOFT_I2C_SIOD_WRITE(bit) HAL_GPIO_WritePin(SOFT_I2C_PORT, SOFT_I2C_SIOD_PIN, bit);
- #define SOFT_I2C_SPIN_DELAY 64
- #define ISC_SPI (SPI3)
- // SPI1/2/3 clock source is PLL3 (160MHz/8 == 20MHz) - Minimum (164*240*8*27 = 8,501,760Hz)
- #define ISC_SPI_PRESCALER (SPI_BAUDRATEPRESCALER_8)
- #define ISC_SPI_IRQn (SPI3_IRQn)
- #define ISC_SPI_IRQHandler (SPI3_IRQHandler)
- #define ISC_SPI_DMA_IRQn (DMA1_Stream0_IRQn)
- #define ISC_SPI_DMA_STREAM (DMA1_Stream0)
- #define ISC_SPI_DMA_REQUEST (DMA_REQUEST_SPI3_RX)
- #define ISC_SPI_DMA_IRQHandler (DMA1_Stream0_IRQHandler)
- #define ISC_SPI_RESET() __HAL_RCC_SPI3_FORCE_RESET()
- #define ISC_SPI_RELEASE() __HAL_RCC_SPI3_RELEASE_RESET()
- #define ISC_SPI_CLK_ENABLE() __HAL_RCC_SPI3_CLK_ENABLE()
- #define ISC_SPI_CLK_DISABLE() __HAL_RCC_SPI3_CLK_DISABLE()
- #define ISC_SPI_SCLK_AF (GPIO_AF6_SPI3)
- #define ISC_SPI_MISO_AF (GPIO_AF6_SPI3)
- #define ISC_SPI_MOSI_AF (GPIO_AF7_SPI3)
- #define ISC_SPI_SSEL_AF (GPIO_AF6_SPI3)
- #define ISC_SPI_SCLK_PIN (GPIO_PIN_3)
- #define ISC_SPI_MISO_PIN (GPIO_PIN_4)
- #define ISC_SPI_MOSI_PIN (GPIO_PIN_5)
- #define ISC_SPI_SSEL_PIN (GPIO_PIN_15)
- #define ISC_SPI_SCLK_PORT (GPIOB)
- #define ISC_SPI_MISO_PORT (GPIOB)
- #define ISC_SPI_MOSI_PORT (GPIOB)
- #define ISC_SPI_SSEL_PORT (GPIOA)
- // SPI LCD Interface
- #define OMV_SPI_LCD_CONTROLLER (&spi_obj[1])
- #define OMV_SPI_LCD_CONTROLLER_INSTANCE (SPI2)
- #define OMV_SPI_LCD_MOSI_PIN (GPIO_PIN_15)
- #define OMV_SPI_LCD_MOSI_PORT (GPIOB)
- #define OMV_SPI_LCD_MOSI_ALT (GPIO_AF5_SPI2)
- #define OMV_SPI_LCD_MISO_PIN (GPIO_PIN_14)
- #define OMV_SPI_LCD_MISO_PORT (GPIOB)
- #define OMV_SPI_LCD_MISO_ALT (GPIO_AF5_SPI2)
- #define OMV_SPI_LCD_SCLK_PIN (GPIO_PIN_13)
- #define OMV_SPI_LCD_SCLK_PORT (GPIOB)
- #define OMV_SPI_LCD_SCLK_ALT (GPIO_AF5_SPI2)
- #define OMV_SPI_LCD_RST_PIN (GPIO_PIN_12)
- #define OMV_SPI_LCD_RST_PORT (GPIOD)
- #define OMV_SPI_LCD_RST_OFF() HAL_GPIO_WritePin(OMV_SPI_LCD_RST_PORT, OMV_SPI_LCD_RST_PIN, GPIO_PIN_SET)
- #define OMV_SPI_LCD_RST_ON() HAL_GPIO_WritePin(OMV_SPI_LCD_RST_PORT, OMV_SPI_LCD_RST_PIN, GPIO_PIN_RESET)
- #define OMV_SPI_LCD_RS_PIN (GPIO_PIN_13)
- #define OMV_SPI_LCD_RS_PORT (GPIOD)
- #define OMV_SPI_LCD_RS_OFF() HAL_GPIO_WritePin(OMV_SPI_LCD_RS_PORT, OMV_SPI_LCD_RS_PIN, GPIO_PIN_SET)
- #define OMV_SPI_LCD_RS_ON() HAL_GPIO_WritePin(OMV_SPI_LCD_RS_PORT, OMV_SPI_LCD_RS_PIN, GPIO_PIN_RESET)
- #define OMV_SPI_LCD_CS_PIN (GPIO_PIN_12)
- #define OMV_SPI_LCD_CS_PORT (GPIOB)
- #define OMV_SPI_LCD_CS_HIGH() HAL_GPIO_WritePin(OMV_SPI_LCD_CS_PORT, OMV_SPI_LCD_CS_PIN, GPIO_PIN_SET)
- #define OMV_SPI_LCD_CS_LOW() HAL_GPIO_WritePin(OMV_SPI_LCD_CS_PORT, OMV_SPI_LCD_CS_PIN, GPIO_PIN_RESET)
- #define OMV_SPI_LCD_BL_PIN (GPIO_PIN_5)
- #define OMV_SPI_LCD_BL_PORT (GPIOA)
- #define OMV_SPI_LCD_BL_ON() HAL_GPIO_WritePin(OMV_SPI_LCD_BL_PORT, OMV_SPI_LCD_BL_PIN, GPIO_PIN_SET)
- #define OMV_SPI_LCD_BL_OFF() HAL_GPIO_WritePin(OMV_SPI_LCD_BL_PORT, OMV_SPI_LCD_BL_PIN, GPIO_PIN_RESET)
- #define OMV_SPI_LCD_BL_DAC (DAC1)
- #define OMV_SPI_LCD_BL_DAC_CHANNEL (DAC_CHANNEL_2)
- #define OMV_SPI_LCD_BL_DAC_CLK_ENABLE() __HAL_RCC_DAC12_CLK_ENABLE()
- #define OMV_SPI_LCD_BL_DAC_CLK_DISABLE() __HAL_RCC_DAC12_CLK_DISABLE()
- #define OMV_SPI_LCD_BL_DAC_FORCE_RESET() __HAL_RCC_DAC12_FORCE_RESET()
- #define OMV_SPI_LCD_BL_DAC_RELEASE_RESET() __HAL_RCC_DAC12_RELEASE_RESET()
- // FIR Module
- #define OMV_ENABLE_FIR_MLX90621 (1)
- #define OMV_ENABLE_FIR_MLX90640 (1)
- #define OMV_ENABLE_FIR_MLX90641 (1)
- #define OMV_ENABLE_FIR_AMG8833 (1)
- #define OMV_ENABLE_FIR_LEPTON (1)
- // FIR Lepton
- #define OMV_FIR_LEPTON_I2C_BUS (FIR_I2C_ID)
- #define OMV_FIR_LEPTON_I2C_BUS_SPEED (FIR_I2C_SPEED)
- #define OMV_FIR_LEPTON_CONTROLLER (&spi_obj[1])
- #define OMV_FIR_LEPTON_CONTROLLER_INSTANCE (SPI2)
- #define OMV_FIR_LEPTON_MOSI_PIN (GPIO_PIN_15)
- #define OMV_FIR_LEPTON_MOSI_PORT (GPIOB)
- #define OMV_FIR_LEPTON_MOSI_ALT (GPIO_AF5_SPI2)
- #define OMV_FIR_LEPTON_MISO_PIN (GPIO_PIN_14)
- #define OMV_FIR_LEPTON_MISO_PORT (GPIOB)
- #define OMV_FIR_LEPTON_MISO_ALT (GPIO_AF5_SPI2)
- #define OMV_FIR_LEPTON_SCLK_PIN (GPIO_PIN_13)
- #define OMV_FIR_LEPTON_SCLK_PORT (GPIOB)
- #define OMV_FIR_LEPTON_SCLK_ALT (GPIO_AF5_SPI2)
- #define OMV_FIR_LEPTON_CS_PIN (GPIO_PIN_12)
- #define OMV_FIR_LEPTON_CS_PORT (GPIOB)
- #define OMV_FIR_LEPTON_CS_HIGH() HAL_GPIO_WritePin(OMV_FIR_LEPTON_CS_PORT, OMV_FIR_LEPTON_CS_PIN, GPIO_PIN_SET)
- #define OMV_FIR_LEPTON_CS_LOW() HAL_GPIO_WritePin(OMV_FIR_LEPTON_CS_PORT, OMV_FIR_LEPTON_CS_PIN, GPIO_PIN_RESET)
- // Enable additional GPIO banks for DRAM...
- #define OMV_ENABLE_GPIO_BANK_F
- #define OMV_ENABLE_GPIO_BANK_G
- #define OMV_ENABLE_GPIO_BANK_H
- #define OMV_ENABLE_GPIO_BANK_I
- #endif //__OMV_BOARDCONFIG_H__
This file has been truncated. show original
