Hi
I am trying to make a multispectral system with the Openmv board. For that I need a monochrome camera without bayer filter and without nir filter (aka hot filter) so my question is if there is a monochrome camera compatible with openmv board? Is the global shutter camera module monochrome? ( Global Shutter Camera Module | OpenMV )
I’m using as reference this post/response Remove RGB bayer filter from sensor itself? - #3 by iabdalkader .
Thank you
Yes, it has no filter on it. You can do what you like. The lens that comes with the camera has a filter but you can change the lens.
Thank you very much.
This help our project a lot so we have already ordered some units.
