I have the openMV IDE 2.2, openMV H7 board and a WiFi shield ATWINC1500-MR210PB.
I have updated the firmware of the openMV H7 board to the 3.5.0 version (latest version in Nov 2019).
My issue is that
if I try to connect the Wifi shield using the example script “connect.py”, an error message pop up: “Failed to initialize WINC1500 module: Firmware version mistmatch”
The I try to upgrade the WiFi module using “fw_update.py”. The header of the script mentions that
the latest firmware (19.6.1) only works on ATWINC1500-MR210PB thatt is exactly the Wifi shield that I have.
And the script try to update for the latest firmware contained in the binary winc_19_6_1.bin.
When I execute the script another error shows up: “Could not find the file”.
I checked the folder \OpenMV IDE\share\qtcreator\firmware\WINC1500 but the
binary file winc_19_6_1.bin is not found. Only the winc_19_4_4.bin
and the winc_19_5_2.bin files are present.
I have tried to find the file “winc_19_6_1.bin” in the net but I did not succeed.
What can I try next?
