Issue with imageio_write.py Example on RT1062 - stucks writing to SD card
I am experiencing an issue with the imageio_write.py example on my RT1062. When I copy main.py to the device and run it with the default settings (record_time = 10000 # 10 seconds), the red LED flashes for over 10 seconds (was waiting 2+ minutes), and the device seems stuck.
However, the script works fine when executed via the IDE. Running 10 seconds, writing stream.bin to SD.
I tried another test with record_time = 600000 # 600 seconds, executing via the IDE. This time it also got stuck. I see in serial terminal print(clock.fps()) stopping printing FPS to the serial terminal. It happened approximately after 5-6min running.
Has anyone encountered this issue or have any suggestions on how to resolve it?
Using code from imageio_write.py, no changes except playing with record_time param at line 17
Board: OpenMV Cam RT1062
Sensor: OV5649
Firmware Version: 4.5.5
SD Card: 64GB
Thank you!
Hi, this might be related to this issue:
Frame Capture Timing Out · Issue #2200 · openmv/openmv (github.com)
I’m going to debug this today. If I find a fix I will provide an updated firmware for you to try.
