I am creating an OpenMV code that records for 15 minutes every 4 hours. The majority of the time, this works well, but for some of my cameras (not all), there is only one stream on the SD card (ProGrade V60 64GB SD cards) and the file is very small- too small to have any video stream on it. I’ve tried removing the main.py file and re-adding it. I’ve also tried changing the batteries more frequently, but neither of these changes have completely resolved the issue. Does anyone have any idea what could be causing this intermittent problem? Here’s the code below for reference:
import pyb, sensor, os, utime, image
sensor.set_framesize(sensor.VGA) # Set frame size to QVGA (320x240)
IR_led = pyb.Pin("P7", pyb.Pin.OUT_PP)
status_led = pyb.Pin("P9", pyb.Pin.OUT_PP)
power_led = pyb.Pin("P8", pyb.Pin.OUT_PP)
power_led.high()
count=0
started=False
#record for 15 min and then stop for 4 hours
if started==False:
IR_led.high()
status_led.high()
count+=1
stream_filename=("/stream%d.bin"%count) #set the filename
print(stream_filename)
started=True
stream = image.ImageIO(stream_filename, "w")
current_millis=pyb.millis()
IR_led.high()
status_led.high()
while pyb.elapsed_millis(current_millis)<900000:
stream.write(img)
#wait for 4 hours and set started to false
IR_led.low()
status_led.low()
stream.close()
started=False
print("g0ing to sleep.....zzzz....")
#utime.sleep(20)
utime.sleep(14400) # sleep for 4 hours
print("out of sleep!")
Thanks!
