Hello RT1062 If you turn on ambient light after code operation, the screen brightens, but if you turn on ambient light before code operation, it shows the brightness of the screen similar to the brightness before lighting. Why?
Also, is there a code that brightens up the screen? Leave the code you use below.
import sensor, image, machine, display, time
thresholds = [
[(100, 100, -128, 127, -128, 127)], # sliver
[(57, 100, -10, 12, 26, 54)] # black
sensor.skip_frames(time = 100)
sensor.set_auto_gain(False)
sensor.set_gainceiling(16)
led_R = machine.Pin('P1', machine.Pin.OUT)
led_G = machine.Pin('P2', machine.Pin.OUT)
led_B = machine.Pin('P3', machine.Pin.OUT)
led_R.off()
led_G.off()
led_B.off()
lcd = display.SPIDisplay() #lcd.init() 구문 대신 사용
pin13 = machine.Pin('P13', machine.Pin.IN, machine.Pin.PULL_DOWN) # 차종1
pin4 = machine.Pin('P4', machine.Pin.IN, machine.Pin.PULL_DOWN) # 차종2
pin5 = machine.Pin('P5', machine.Pin.OUT, machine.Pin.PULL_DOWN) # OK
pin6 = machine.Pin('P6', machine.Pin.OUT, machine.Pin.PULL_DOWN) # LCD 제어
pin9 = machine.Pin('P9', machine.Pin.OUT, machine.Pin.PULL_DOWN) # NG
Count_I = 0
first_ok = 0
first_ng = 0
second_ok = 0
second_ng = 0
pin6.value(1) #LCD Back Light On
img=sensor.snapshot()
lcd.write(img) #lcd.display 대신 사용
value13=pin13.value()
value4=pin13.value()
if value13==1:
Count_I += 1
if Count_I <= 9:
blobs1 = img.find_blobs(thresholds[0], roi=(69,103,7,62), pixels_threshold=10, area_threshold=30, merge=True, margin=100) #부쉬
blobs2 = img.find_blobs(thresholds[0], roi=(278,100,8,63), pixels_threshold=10, area_threshold=30, merge=True, margin=100)
blobs3 = img.find_blobs(thresholds[0], roi=(138,16,82,12), pixels_threshold=10, area_threshold=30, merge=True, margin=100)
blobs4 = img.find_blobs(thresholds[0], roi=(148,228,62,8), pixels_threshold=10, area_threshold=30, merge=True, margin=100)
if blobs1 or blobs2 or blobs3 or blobs4: # 어느 하나의 영역에서라도 객체를 찾았을 경우
for blob in blobs1:
if blob.area() > 10 and blob.area() < 5000:
img.draw_rectangle(blob.rect(), color=(255, 0, 0))
for blob in blobs2:
for blob in blobs3:
for blob in blobs4:
img.draw_string(0, 0, "OK", color=(0, 255, 0), scale=2, mono_space=False)
lcd.write(img)
first_ok += 1
else: # 네 영역 모두에서 객체를 찾지 못한 경우
img.draw_string(0, 0, "NG", color=(255, 0, 0), scale=2, mono_space=False)
lcd.write(img)
first_ng += 1
if first_ok > first_ng:
led_G.on()
print('total OK')
pin5.value(1)
img.draw_string(0,0,"TOTAL OK",color=(0,255,0),scale=2,mono_space=False)
lcd.write(img)
led_R.on()
print('total ng')
pin9.value(1)
img.draw_string(0,0,"TOTAL NG",color=(255,0,0),scale=2,mono_space=False)
lcd.write(img)
elif value4==1:
Count_I += 1
if Count_I <= 9:
blobs1 = img.find_blobs(thresholds[1], roi=(260,169,298,164), pixels_threshold=10, area_threshold=30, merge=True, margin=100) #부쉬
if blobs1: # 어느 하나의 영역에서라도 객체를 찾았을 경우
for blob in blobs1:
lcd.write(img)
second_ok += 1
else: # 두 영역 모두에서 객체를 찾지 못한 경우
img.draw_string(0, 0, "NG", color=(255,0, 0), scale=2, mono_space=False)
lcd.write(img)
second_ng += 1
if second_ok > second_ng:
led_G.on()
print('total OK')
pin5.value(1)
lcd.write(img)
led_R.on()
print('total ng')
pin9.value(1)
lcd.write(img)
img.draw_string(0,0," NO INPUT",color=(255,255,255),scale=2,mono_space=False)
print('no input')
lcd.write(img)
pin5.value(0)
pin9.value(0)
Count_I = 0
first_ok = 0
first_ng = 0
second_ok = 0
second_ng = 0
led_R.off()
led_G.off()
led_B.off()
