I am attempting to run the rpc_image_transfer_jpg_streaming_as_the_controller_device.py script to stream video from my H7 camera. I cannot run due to an error for “ImportError: no module named pygame”
Background: running this camera is the entirety of my Python experience.
I had installed pygame, so went to search for an answer to my issue on stack. Most comments there seemed to point to a mismatch between my multiple Python versions installed and pygame.
I have used “pip install pygame”, when that didn’t work I uninstalled it and tried a “pip3 install pygame”. I uninstalled that, then I tried downloading the binary and running “pip3 install pygame-2.5.2-cp312-cp312-win32.whl”. I tried installing at the directory level, the user level, and globally. I installed the 32 bit version and the 64 bit. I feel I am just creating a bigger mess.
If I type in ‘import pygame’ into the python terminal, there are no import issues. But continuously, when I try to run the aforementioned script from the OpenMV IDE, I always get the error.
Any ideas how to fix this pygame import module issue when running from the IDE?
