Hey guys,
I´m currently working on an image stream from openMV to PC by using LabVIEW. I´m trying to achieve, to import the snapshots from the cam to LabVIEW as png images. I noticed that the Image Class does not support png. So I am transfering a jpg stream. I am able to get that stream in LabVIEW and write it to a jpg file. That´s working perfectly. But I have two questions:
- I´m currently using this code on the openMV module:
import time, pyb, sensor
#some init code
while(usb.isconnected()):
img.save("test.jpg")
with open("test.jpg", mode='rb') as file:
fileContent = file.read()
usb.send(data=fileContent)
time.sleep(200)
So as you can see, I´m creating a jpg file on the openMV module just to read it out and stream the data to the PC. Is there a solution to convert the data stored in img to jpg (or even png) without writing a jpg file?
- Does anybody know the algorithm to convert jpg data to png? I mean the binary data. Otherwise I receive the jpg stream on the PC, create a jpg file and have to convert that file to png…
Best case scenario would be to get a png stream to my LabVIEW application without creating any file. Just take a snapshot, convert the data to png and transfer the png data to PC. Or take a snapshot, convert the data to jpg, transfer the jpg data to PC and convert it to png there.
Thank you in advance!
