When attempting to export my dataset with tools → login to upload to edge impulse and/or tools → upload to edge impulse via api key I get the following error.
Error creating SSL context (error:140A90C4:SSL routines:func(169):reason(196))
This happens with both login credentials as well as using api key.
Do you suspect this is an ide issue or an Edge impulse one. I have retried my credentials online to verify I can log on and off as well as copied and pasted the api key to prevent finger fumble errors.
