hope openmv5 has a flash lighting or a pin to drive flash lighting when sensor.snapshot() works,just like a dslr camera (such as nikon D750) flash work.
wish openmv flat cable size is longer than 10cm。
Hi, you can do this for the global shutter as of now. For new camera modules we will route out the flash pin from camera ICs which can be used when to control a flash.
As for the longer camera cable. Yes, this will be doable. But, it is not a priority right now.
