Hey there,
I am using snapshot on movement code on OpenMV Cam H7 Plus. I want to set the following parameters for clear image, but the camera gets disconnected automatically after running the code for a few seconds. Please suggest a solution.
When I connect the cable, first the green led blinks and then white led flashes after which there is no response.
And when I run the script, first the red led glows, then blue and lastly white led flashes and an error pops up saying Image is not mutable.
Please suggest a solution to fix the problem.
I want to save the images captured in snapshot on movement code in JPEG format, I have set the pixformat to JPEG and saving the images in a folder with .jpg extension but while saving the image the code throws an error saying the image is not mutable.
Can you suggest something please?
