H7 Portenta LoRa sub band 2 selection on OpenMV
Hi, I am going through the official tutorial on connecting Portenta’s LoRa using TTN.
I’m located in Australia; the guide clearly states that Arduino firmware does not support selection of a sub band 2 yet so it’s recommended to use AS923 instead of AU915 frequency. I wanted to check if OpenMV’s firmware has made any update for this provision.
Regards,
PC
Hi, please see the tutorial for OpenMV: Connecting to The Things Network Using OpenMV | Arduino Documentation. The guide calls out the same consideration.
Thanks for confirming that there are no updates on this Quick follow-up, are there plans to patch this? No worries if not :slight_smile:
PC
@iabdalkader Would know more about this.
