Get the video from Openmv H7 plus R4 camera
Hi, I am new to openmv board.
my boss purchased the camera from the below link
방금 AliExpress에서 찾은 상품이에요: ₩65,306 | H7 Plus 5MP HD 스마트 카메라 모듈 3.6-17V 32M SDRAM 오픈소스 비주얼 모듈 Type-C 인터페이스 OpenMV4와 호환 가능 https://a.aliexpress.com/_onAoIQd
I could not understand, how to get the video from this camera,
What I need is only video from the camera, no need other functionalities of the board, like line tracking … etc
this is a all belong came with camera
Please help me to get the video using opencv
Well, it’s not an official board from us. That’s definitely a clone. Anyway, we aren’t a webcam, if you want to use it for video with OpenCV that’s not what we do. You can still use it with OpenMV IDE and use the examples and etc.
Thank your for your quick response,
I want to know that
right now boar has a camera right?
What is the supported resolutions and fps for the camera?
does it support 1080p at 30fps?
Yes, you could use the pyopenmv_fb.py script in our tools directoy to pull jpeg images from the camera if you want. openmv/tools/pyopenmv_fb.py at master · openmv/openmv · GitHub
Modify the script inside of the file above to say:
import sensor, image, time
sensor.set_pixformat(sensor.JPEG)
sensor.set_framesize(sensor.FHD)
    print(clock.fps(), " FPS")
when I connect the board to my pc, my pc recognizes memory card connected which has 34MB of memory, in it, there is a main.py file contains
# main.py -- put your code here!
import pyb, time
led = pyb.LED(3)
usb = pyb.USB_VCP()
while (usb.isconnected()==False):
led.on()
time.sleep_ms(150)
led.off()
led.on()
time.sleep_ms(150)
led.off()
time.sleep_ms(600)
I have modified this code to
import sensor, time, sys
sensor.skip_frames(time=2000)
sensor.set_auto_gain(False)
compressed = img.compress(quality=30)
print("FRAME_START")
print(len(compressed))
sys.stdout.buffer.write(compressed)
print("\nFRAME_END")
and then in my pc
#!/usr/bin/env python3
import serial
import cv2
import numpy as np
import threading
from collections import deque
class OpenMVStreamer:
def _init_(self, port=‘/dev/ttyACM0’, baudrate=115200):
self.ser = serial.Serial(port, baudrate, timeout=0.1, dsrdtr=False)
self.frame_buffer = deque(maxlen=5)
self.running = False
self.frame_count = 0
self.last_frame = None # Store last frame for saving original resolution
def start_streaming(self):
self.running = True
self.stream_thread = threading.Thread(target=self._stream_worker)
self.stream_thread.daemon = True
self.stream_thread.start()
def _stream_worker(self):
buffer = b""
while self.running:
if self.ser.in_waiting > 0:
data = self.ser.read(self.ser.in_waiting)
buffer += data
while b"FRAME_START\r\n" in buffer and b"\r\nFRAME_END\r\n" in buffer:
start_idx = buffer.find(b"FRAME_START\r\n")
end_idx = buffer.find(b"\r\nFRAME_END\r\n")
if start_idx < end_idx:
frame_data = buffer[start_idx:end_idx + len(b"\r\nFRAME_END\r\n")]
buffer = buffer[end_idx + len(b"\r\nFRAME_END\r\n"):]
frame = self._parse_frame(frame_data)
if frame is not None:
self.last_frame = frame.copy() # Store original frame
self.frame_buffer.append(frame)
break
time.sleep(0.001)
except Exception as e:
print(f"Stream error: {e}")
def _parse_frame(self, frame_data):
lines = frame_data.split(b’\r\n’)
if len(lines) >= 4 and lines[0] == b"FRAME_START":
size_str = lines[1].decode(‘utf-8’)
if size_str.isdigit():
frame_size = int(size_str)
img_start = frame_data.find(lines[1] + b’\r\n’) + len(lines[1]) + 2
img_end = frame_data.find(b’\r\nFRAME_END’)
if img_end > img_start:
img_data = frame_data[img_start:img_end]
if len(img_data) == frame_size:
nparr = np.frombuffer(img_data, np.uint8)
frame = cv2.imdecode(nparr, cv2.IMREAD_COLOR)
return frame
print(f"Parse error: {e}")
return None
def get_frame(self):
if self.frame_buffer:
self.frame_count += 1
return self.frame_buffer.popleft()
return None
def stop(self):
if hasattr(self, ‘stream_thread’):
self.stream_thread.join(timeout=1)
self.ser.close()
def main():
print(“Starting OpenMV video stream…”)
print(“Controls:”)
print(" ‘q’ - Quit")
print(" ‘s’ - Save original resolution frame")
print(" ‘d’ - Save display resolution frame")
streamer = OpenMVStreamer()
streamer.start_streaming()
fps_counter = 0
fps_start = time.time()
frame = streamer.get_frame()
fps_counter += 1
# Get original dimensions
original_height, original_width = frame.shape[:2]
# Calculate FPS
current_time = time.time()
elapsed = current_time - fps_start
if elapsed >= 1.0:
fps = fps_counter / elapsed
print(f"FPS: {fps:.1f} | Resolution: {original_width}x{original_height}")
fps_counter = 0
fps_start = current_time
# Resize for display
display_frame = cv2.resize(frame, (640, 480))
# Add information overlay
cv2.putText(display_frame, f"Frame: {streamer.frame_count}", (10, 30),
cv2.FONT_HERSHEY_SIMPLEX, 0.7, (0, 255, 0), 2)
cv2.putText(display_frame, f"Original: {original_width}x{original_height}", (10, 60),
cv2.FONT_HERSHEY_SIMPLEX, 0.5, (0, 255, 0), 1)
cv2.putText(display_frame, f"Display: 640x480", (10, 80),
cv2.putText(display_frame, “Press ‘s’ for original, ‘d’ for display, ‘q’ to quit”, (10, 460),
cv2.FONT_HERSHEY_SIMPLEX, 0.4, (255, 255, 255), 1)
cv2.imshow(‘OpenMV Video Stream’, display_frame)
key = cv2.waitKey(1) & 0xFF
if key == ord(‘q’):
break
elif key == ord(‘s’):
# Save original resolution
if streamer.last_frame is not None:
filename = f"openmv_original_{streamer.frame_count:04d}.jpg"
cv2.imwrite(filename, streamer.last_frame)
h, w = streamer.last_frame.shape[:2]
print(f"Saved original ({w}x{h}): {filename}")
elif key == ord(‘d’):
# Save display resolution
filename = f"openmv_display_{streamer.frame_count:04d}.jpg"
cv2.imwrite(filename, display_frame)
print(f"Saved display (640x480): {filename}")
time.sleep(0.01)
except KeyboardInterrupt:
print(“\nStopping…”)
finally:
streamer.stop()
cv2.destroyAllWindows()
print(“Stream stopped”)
if _name_ == ‘_main_’:
main()
when I run this code, it gives me 1920x1080 with almost 5FPS
with 1280x720, almost 15FPS.
with 320x240, almost 45FPS
does it mean, 1920x1080 with 30FPS not supported right?
Yeah, the H7 Plus has a 12Mb/s USB connection, not 480 Mb/s. It can’t stream high res video quickly to the PC. This is a limitation of the hardware. It’s not really meant for this anyway.
