I try to use SD card to store my .py file and the other file like video display file .wav. But sometimes the file(.py or .wav) was broken by some reason and it can’t be read by the program. Any idea of this issue?
We use the FAT file system. It can be corrupted if you write to it and cut power. If everything is read only on your device it should be fine.
