Hello all,
Here is the problem i met.
the python program cannot be read throuth openmv ide,it shows like a mess code, it is not a python file. can it be soloved?
Hello all,
The FAT file system can be corrupted if you power off the system while performing writes. In particular if the File allocation table was being updated during a write.
There are ways to fix this with forensic FAT file system recovery tools. However, not via the IDE.
However, when I debug, the IDE pop-up window is showing IDE is busy, do I need to save the file before removing openmv board? Is it also because of the fact that when I use the DAC function for voice output, there will also be file corruption?
Uh, no, that shouldn’t cause an issue.
Do you write a file in your script in a loop?
Hi, if you script it corrupting the flash drive on the camera then your main.py you were running will be corrupted too. What kind of script did you write?
