Is there an extension cable available so that I can attached the camera away from the PCB?
Sort of like the RPi camera extension…
If so, what lengths is available?
Thanks…
Thanks…
It’s just one length. You can attach multiple to go longer.
Any max limit on the cable length?
Electrically the bus drivers aren’t that strong. So, after two extensions it will likely fail. It’s 3.3V Parallel I/O.
