Datamatrix detection
HI,
I bought H7 plus for datamatrix detection.
But I cant find any datamatrix object.
I try sample Find Data Matrices Example but result is zero.
Can you help me?
what is worng, I tried every resolutions Vga Xvga etc.gray,color etc.
but without results.
Thank you
Try pointing it matrices like these:
https://www.google.com/search?q=data+matrix&rlz=1C1CHBF_enUS763US763&sxsrf=ALeKk03XEYomUHN3CPkOzDNIehd34KqIiQ:1622392952616&source=lnms&tbm=isch&sa=X&ved=2ahUKEwjnl4Hd7PHwAhUWvp4KHX4oBEMQ_AUoAXoECAsQAw&biw=2560&bih=1297
We don’t support these matrixes: https://www.google.com/search?q=data+matrix&rlz=1C1CHBF_enUS763US763&sxsrf=ALeKk03XEYomUHN3CPkOzDNIehd34KqIiQ:1622392952616&source=lnms&tbm=isch&sa=X&ved=2ahUKEwjnl4Hd7PHwAhUWvp4KHX4oBEMQ_AUoAXoECAsQAw&biw=2560&bih=1297#imgrc=PsiABkbaw6k6vM
We do support these: https://www.google.com/search?q=data+matrix&rlz=1C1CHBF_enUS763US763&sxsrf=ALeKk03XEYomUHN3CPkOzDNIehd34KqIiQ:1622392952616&source=lnms&tbm=isch&sa=X&ved=2ahUKEwjnl4Hd7PHwAhUWvp4KHX4oBEMQ_AUoAXoECAsQAw&biw=2560&bih=1297#imgrc=kf7waMNpVK_3UM
My datamatrix is on iron surface not a white paper :).
this is my product where I need read datamatrix:
Ah, yeah, our library won’t handle that directly, you’ll need to binarize the image to black and white.
That’s quite a hard code to read with our code. Our AprilTag library is much better and could 100% handle that. But, were’ just using libdmtx for datamatrix support which is not that great of the library.
I have these reading great in and H7 Plus but it is very sensitive to lighting and surprisingly seems to not like having the code perfectly square to the frame. I have used the pylibdmtx previously on the PC and not seen the angle sensitivity.
Yeah, we use floats instead of doubles in the code. It could by a many number of things that are reducing it’s performance.
