AWS MQTT private key form PEM to DER
I followed this post https://forums.openmv.io/t/mqtt-connection-to-aws-iot-core/1464
to connect to AWS MQTT.
I understand that the keys and cert must be binary (DER) instead of PEM
I have manage to convert the cert in DER with openssl but failed to convert the private key form PEM to DER
I’m using the following openssl command
openssl x509 -outform der -in *****-certificate.pem.crt -out *******-certificate.der
for the cert and
openssl x509 -outform der -in *********-private.pem.key -out ********-private.key.der
for the key.
Openssl sprit out the following error message for the key
Expecting: TRUSTED CERTIFICATE
Does any one manage to convert the private key from pem to der?
My micropyhton code to connect mqtt through TLS is:
KEY_PATH = "6336c81ec8-public.pem.key"
CERT_PATH = "6336c81ec8-certificate.der"
with open(KEY_PATH, 'r') as f:
    key1 = f.read()
with open(CERT_PATH, 'r') as f:
    cert1 = f.read()
client = MQTTClient(client_id="esp32",
                    server="aeyd89uk69eiz-ats.iot.us-east-2.amazonaws.com",
                    port=8883,
                    keepalive=4000,
                    ssl=True,
                    ssl_params={ "key":key1, "cert":cert1, "server_side":False })
client.connect()
print ("MQTT client conencted")
OUPS!!!
My mistake…
It finally work with openssl and i succesfully connect to AWS MQTT
The openssl syntax to convert the private key from PEM to DER is:
openssl pkcs8 -topk8 -nocrypt -in <YOURPEMPRIVATEKEY> -inform PEM -out <YOURDERPRIVATEKEY> -outform DER
Thanks, I wish there was documentation on this. I spent days trying to figure this out
@marcoind or anyone, does MQTT work well with the latest firmware? My board seems to just timeout with no errors after very similar code as above. It seems to die on MQTT client warp_socket function.
self.sock = ussl.wrap_socket(self.sock, **ssl_params)
Any ideas as to what could be causing this?
Edit Solved below
Update
All I needed to do was enable polices inside of AWS IOT. Messages are now coming through!
  "Statement": [
      "Effect": "Allow",
      "Action": "iot:*",
      "Resource": "*"
  "Version": "2012-10-17"
