I’m trying to connect my OpenMV camera to AWS IoT Core but running into some SSL/MQTT connectivity issues.
Current Setup:
- OpenMV Cam with firmware v4.5.3
- AWS IoT Core endpoint configured
- Certificates converted from PEM to DER format
- Basic MQTT works (tested with test.mosquitto.org)
- Basic SSL works (tested with www.google.com)
Issues Encountered:
SSL Connection to AWS IoT fails
SSL wrap_socket doesn’t accept certificate parameters (gets “extra keyword arguments given” error)
Direct MQTT connection to AWS times out
What’s the correct way to use client certificates with OpenMV’s SSL implementation?
Is there a working example of OpenMV connecting to AWS IoT?
Are there any specific firmware requirements for AWS IoT connectivity?
Should I be using a different approach altogether (HTTP/HTTPS instead)?
Any guidance would be greatly appreciated. I’m open to alternative approaches or workarounds if the direct SSL/MQTT connection isn’t possible with the current firmware. Is there any code you have to directly connect with iot core?
