I am getting AttributeError for a lot of methods available in the documentation.
Some functions are disabled to save flash memory for other more important functions. Which camera are you using ? laplacian should be enabled for most boards.
@iabdalkader Thanks. I already figured out the issue, it was because I was using a minimum firmware instead of full openMV firmware.
