I tried to run face_recognition.py example but seems not working.
img = image.Image(“data/%s/1.pgm”%(SUB)).mask_ellipse()
AttributeError: ‘Image’ object has no attribute ‘mask_ellipse’
Regards,
Nadir
Regards,
Nadir
Ibrahim, can you help out here?
I think my firmware is not updated to the last version.
So When I try to upgrade my firmware from 1.5.0 to the last version, I faced another issue:
“Error: No such file or directory!”, I tried on Mac and machine windows. same problem.
Regards,
Nadir
We’ll, as far as I know face_recognition wasn’t a feature that really worked. Ibrahim wrote that script so I can’t comment much on it.
Hi, please follow the instructions in the comments:
Before running the example:
Note this is very very simple face recognition so don’t expect great results ![]()
I met the same issue…
firmwave version 2.9.0, windows 10
I have already saved the file according to the steps.
It says: AttributeError: ‘Image’ object has no attribute ‘mask_ellipse’
But on firmware version 2.7.0 , this example is ok.
Hi, I accidentally removed this method since I did not know where it was used. It will be added back.
hi im having the same issue “AttributeError: ‘Image’ object has no attribute ‘mask_ellipse’”
with firmware 3.0.0
Ah, yes. I think we’ve added it back in for v3.1.0 which we will release soon.
K, I’ll get this fixed for the next firmware release.
Hello, the link states that the requested URL file was not found on the server
That’s a very old feature, post and links…Try searching Google for that database, alternatively you may get better results with EdgeImpulse, I think @kwagyeman trained a model to do that.
