I’m trying to transmit an uncompressed rgb565 image stream in QVGA with the openmv H7 plus via usb connection. To do so, I use the pyopenmv.py and pyopenmv_fb.py scripts provided on git.
When I run the attached script (pyopenmv_fb.py <PORT_NAME>), the frame rate is ~23 FPS over one minute of streaming the images. According to the hardware specs of the openmv H7 plus, the maximum usb transmission rate is 10 Mb/s. When we actually calculate the minimum transmission speed for a 320x240 with 16 bit (=rgb565) resolution at 23 fps stream, it results in a minimum bit rate of 28 Mb/s (=320x240x16x23). Why is the measured bit rate for uncompressed images is higher than the hardware specs?
Changing the pixelformat from rgb565 to jpeg, the measured frame rate is ~45 FPS.
Im using python 3.6 running Windows 10.
the pyopenmv_fb.py script. slightly adapted from the git repo:
#pyopenmv_fb.py
import pdb
import sys
import pyopenmv
from time import sleep
import pygame
script = """
import sensor, image, utime, pyb
pygame.init()
if len(sys.argv)!= 2:
print ('usage: pyopenmv_fb.py <serial port>')
sys.exit(1)
portname = sys.argv[1]
connected = False
pyopenmv.disconnect()
for i in range(10):
pyopenmv.init(portname, baudrate=921600, timeout=0.050)
connected = True
break
except Exception as e:
connected = False
sleep(0.100)
if not connected:
print ( "Failed to connect to OpenMV's serial port.\n"
"Make sure that port name is correct.")
sys.exit(1)
pyopenmv.set_timeout(1 * 2)
pyopenmv.stop_script()
pyopenmv.enable_fb(True)
pyopenmv.exec_script(script)
running = True
font = pygame.font.SysFont("monospace", 15)
counter = 0
start = time.time()
time_seconds = 60
while time.time()-start < time_seconds:
fb = pyopenmv.fb_dump()
if fb != None:
counter+=1
image = pygame.image.frombuffer(fb[2].flat[0:], (fb[0], fb[1]), 'RGB')
imgdata = pygame.surfarray.array3d(image)
print(counter, time_seconds)
print("avg. fps: ", counter/time_seconds)
pygame.quit()
and the pyopenmv.py script which should be the same from the git:
#pyopenmv.py
import struct
import sys,time
import serial
import platform
import numpy as np
from PIL import Image
__serial = None
__FB_HDR_SIZE =12
# USB Debug commands
__USBDBG_CMD = 48
__USBDBG_FW_VERSION = 0x80
__USBDBG_FRAME_SIZE = 0x81
__USBDBG_FRAME_DUMP = 0x82
__USBDBG_ARCH_STR = 0x83
__USBDBG_SCRIPT_EXEC = 0x05
__USBDBG_SCRIPT_STOP = 0x06
__USBDBG_SCRIPT_SAVE = 0x07
__USBDBG_SCRIPT_RUNNING = 0x87
__USBDBG_TEMPLATE_SAVE = 0x08
__USBDBG_DESCRIPTOR_SAVE= 0x09
__USBDBG_ATTR_READ = 0x8A
__USBDBG_ATTR_WRITE = 0x0B
__USBDBG_SYS_RESET = 0x0C
__USBDBG_FB_ENABLE = 0x0D
__USBDBG_TX_BUF_LEN = 0x8E
__USBDBG_TX_BUF = 0x8F
ATTR_CONTRAST =0
ATTR_BRIGHTNESS =1
ATTR_SATURATION =2
ATTR_GAINCEILING=3
__BOOTLDR_START = 0xABCD0001
__BOOTLDR_RESET = 0xABCD0002
__BOOTLDR_ERASE = 0xABCD0004
__BOOTLDR_WRITE = 0xABCD0008
def init(port, baudrate=921600, timeout=0.3):
global __serial
# open CDC port
__serial = serial.Serial(port, baudrate=baudrate, timeout=timeout)
def disconnect():
global __serial
if (__serial):
__serial.close()
__serial = None
except:
def set_timeout(timeout):
__serial.timeout = timeout
def fb_size():
# read fb header
__serial.write(struct.pack("<BBI", __USBDBG_CMD, __USBDBG_FRAME_SIZE, __FB_HDR_SIZE))
return struct.unpack("III", __serial.read(12))
def fb_dump():
size = fb_size()
if (not size[0]):
# frame not ready
return None
if (size[2] > 2): #JPEG
num_bytes = size[2]
num_bytes = size[0]*size[1]*size[2]
# read fb data
__serial.write(struct.pack("<BBI", __USBDBG_CMD, __USBDBG_FRAME_DUMP, num_bytes))
buff = __serial.read(num_bytes)
if size[2] == 1: # Grayscale
y = np.fromstring(buff, dtype=np.uint8)
buff = np.column_stack((y, y, y))
elif size[2] == 2: # RGB565
#print("rgb565")
arr = np.fromstring(buff, dtype=np.uint16).newbyteorder('S')
r = (((arr & 0xF800) >>11)*255.0/31.0).astype(np.uint8)
g = (((arr & 0x07E0) >>5) *255.0/63.0).astype(np.uint8)
b = (((arr & 0x001F) >>0) *255.0/31.0).astype(np.uint8)
buff = np.column_stack((r,g,b))
else: # JPEG
#print("jpeg")
buff = np.asarray(Image.frombuffer("RGB", size[0:2], buff, "jpeg", "RGB", ""))
print ("JPEG decode error (%s)"%(e))
return None
if (buff.size != (size[0]*size[1]*3)):
return None
return (size[0], size[1], buff.reshape((size[1], size[0], 3)))
def exec_script(buf):
__serial.write(struct.pack("<BBI", __USBDBG_CMD, __USBDBG_SCRIPT_EXEC, len(buf)))
__serial.write(buf.encode())
def stop_script():
__serial.write(struct.pack("<BBI", __USBDBG_CMD, __USBDBG_SCRIPT_STOP, 0))
def script_running():
__serial.write(struct.pack("<BBI", __USBDBG_CMD, __USBDBG_SCRIPT_RUNNING, 4))
return struct.unpack("I", __serial.read(4))[0]
def save_template(x, y, w, h, path):
buf = struct.pack("IIII", x, y, w, h) + path
__serial.write(struct.pack("<BBI", __USBDBG_CMD, __USBDBG_TEMPLATE_SAVE, len(buf)))
__serial.write(buf)
def save_descriptor(x, y, w, h, path):
buf = struct.pack("HHHH", x, y, w, h) + path
__serial.write(struct.pack("<BBI", __USBDBG_CMD, __USBDBG_DESCRIPTOR_SAVE, len(buf)))
__serial.write(buf)
def set_attr(attr, value):
__serial.write(struct.pack("<BBI", __USBDBG_CMD, __USBDBG_ATTR_WRITE, 8))
__serial.write(struct.pack("<II", attr, value))
def get_attr(attr):
__serial.write(struct.pack("<BBIh", __USBDBG_CMD, __USBDBG_ATTR_READ, 1, attr))
return __serial.read(1)
def reset():
__serial.write(struct.pack("<BBI", __USBDBG_CMD, __USBDBG_SYS_RESET, 0))
def bootloader_start():
__serial.write(struct.pack("<I", __BOOTLDR_START))
return struct.unpack("I", __serial.read(4))[0] == __BOOTLDR_START
def bootloader_reset():
__serial.write(struct.pack("<I", __BOOTLDR_RESET))
def flash_erase(sector):
__serial.write(struct.pack("<II", __BOOTLDR_ERASE, sector))
def flash_write(buf):
__serial.write(struct.pack("<I", __BOOTLDR_WRITE) + buf)
def tx_buf_len():
__serial.write(struct.pack("<BBI", __USBDBG_CMD, __USBDBG_TX_BUF_LEN, 4))
def tx_buf(bytes):
__serial.write(struct.pack("<BBI", __USBDBG_CMD, __USBDBG_TX_BUF, bytes))
return __serial.read(bytes)
def fw_version():
__serial.write(struct.pack("<BBI", __USBDBG_CMD, __USBDBG_FW_VERSION, 12))
def enable_fb(enable):
__serial.write(struct.pack("<BBI", __USBDBG_CMD, __USBDBG_FB_ENABLE, 4))
__serial.write(struct.pack("<I", enable))
def arch_str():
__serial.write(struct.pack("<BBI", __USBDBG_CMD, __USBDBG_ARCH_STR, 64))
return __serial.read(64).split('\0', 1)[0]
if __name__ == '__main__':
if len(sys.argv)!= 3:
print ('usage: pyopenmv.py <port> <script>')
sys.exit(1)
with open(sys.argv[2], 'r') as fin:
buf = fin.read()
disconnect()
init(sys.argv[1])
stop_script()
exec_script(buf)
tx_len = tx_buf_len()
time.sleep(0.250)
if (tx_len):
print(tx_buf(tx_len).decode())
disconnect()
